Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
January 15, 2021, 03:12:00 PM
Home
Forum
Search
Members Map
Photos Gallery
Login
Register
Triumph Tiger 800 Forum
Misc Technical Help Required
Engine Braking
Print
Pages:
1
2
3
Go Down
Author
Topic: Engine Braking (Read 2799 times)
fac191
Premier Member
Tiger Jedi
Bike: Super Tenere ES
Re: Engine Braking
Reply #10 on:
November 26, 2020, 09:36:11 AM »
You could get the ECU released and get it set up how you want. Lol when I went from my Tiger to the Super Tenere the engine braking was so severe it felt like you were going over the bars !. Had it remapped straight away it felt almost unrideable.
Logged
Aussie Tiger
Tiger Pro
Bike: 900 Rally Pro
Re: Engine Braking
Reply #11 on:
November 26, 2020, 09:38:24 AM »
Chain too tight?
Logged
Flyingbanana
Tiger Member
Bike: Tiger 800,SV1000
Re: Engine Braking
Reply #12 on:
November 27, 2020, 09:43:44 AM »
Going to chk the chain this weekend. really tough to do when getting home from work in the dark dank weather !
Logged
Grumps
Tiger Jedi
Bike: 2018 800 Xca
Re: Engine Braking
Reply #13 on:
November 27, 2020, 10:49:58 AM »
Originally Posted by
Aussie Tiger
Chain too tight?
That's a good shout. But he does say it freewheels ok so maybe not. But always worth checking anyway.
Logged
2018 Xca. Suzuki GT380. Yamaha Xmax
Flyingbanana
Tiger Member
Re: Engine Braking
Reply #14 on:
November 27, 2020, 11:32:28 AM »
the chain is ready for a tickle
Logged
romanrick
Tiger Member
Bike: tiger 800xc
Re: Engine Braking
Reply #15 on:
November 28, 2020, 05:46:21 PM »
Did you check the brakes are not binding after a ride, they can start to bind with use then free up as they cool. I would also check all the running gear, is the chain too tight, wheel bearings ok, tires pressures correct ?
Logged
fac191
Premier Member
Tiger Jedi
Re: Engine Braking
Reply #16 on:
November 28, 2020, 08:14:14 PM »
Just for the sake of it i would also check the front sprocket out.
Logged
Flyingbanana
Tiger Member
Re: Engine Braking
Reply #17 on:
December 01, 2020, 10:15:08 AM »
Morning all you lovely people. Checked the chain at the w/end and was a tad slack so tightened it.
I always find the old chain tinkering a bit of a pain.Maybe someone could enlighten me. There is always a tight spot - Why as this always puts my mind in doubt when you are setting the tension as the tight spot can seem really tight when the slackest part is now in the correct tension measurements. The chain is not that old either.
Logged
Grumps
Tiger Jedi
Bike: 2018 800 Xca
Re: Engine Braking
Reply #18 on:
December 01, 2020, 12:23:47 PM »
Chains should be adjusted at the tight spot. If you set at the slack it means that you get a 'jerk' at the tight spot that can damage sprockets and bearings.
Logged
Flyingbanana
Tiger Member
Re: Engine Braking
Reply #19 on:
December 01, 2020, 12:52:47 PM »
that's where i took the measurements, right at the tight spot.
Logged
Print
Pages:
1
2
3
Go Up
Engine Braking
Subframe bolts
philmcglass
Today
at 02:56:36 PM
Megameet 2021 postponed
2021 Tiger Mega Meet - Germany
Stevie.P
Today
at 12:54:41 PM
TC disabled and Engine warning light
Brakes and ABS
Stevie.P
Today
at 11:55:04 AM
XCa Rear Sag - Confused!
Ragtop
Today
at 11:43:20 AM
Is Tiger 900/800 right for me?
ProfThunder
Today
at 10:37:55 AM
Automatic Chain Oilers; Best oil for UK winter;
Jex
Today
at 09:48:40 AM
Bar Muffs
Accessories and Products
Ragtop
Today
at 09:35:01 AM
Howzit from a Zimbo now living in Dorset, UK
New Members
chico
Today
at 05:42:01 AM
Differences between the maps for Xrx route and Xcx Chemin
ECU Re-Mapping and Tuning
Aussie Tiger
Today
at 02:20:47 AM
Tiger 900 - Pyramid Plastics rear hugger
fastnfat
Yesterday
at 10:08:28 PM
