Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: chain oilers  (Read 6095 times)
Re: chain oilers
« Reply #30 on: December 26, 2020, 01:29:14 AM »
There are two rubbing surfaces - the pin on the outer plates goes through the bush on the inner plates, and that friction interface is permanently lubricated by the grease sealed in by the O/Z/W/X rings. The roller rotates around the bush and the outer surface of the roller is the surface that the sprocket goes onto, and the roller/bush interface is lubricated by chain lube.
Re: chain oilers
« Reply #31 on: December 26, 2020, 05:42:54 AM »
Aren't both inner & outer surfaces of the bush permanently lubricated by the grease sealed-in upon chain assembly? I.E. the outer surface of the pin, the inner surface of the bush, the outer surface of the bush, and the inner surface of the roller -- are the greased & sealed interfaces (rubbing surfaces).
The chains rollers (outer surfaces) are, then, (ideally) not rubbing surfaces and external lube may, when applied, offer a protective film and a pressure cushion to the roller sprocket interface.
« Last Edit: December 26, 2020, 06:14:28 AM by AvgBear »
Re: chain oilers
« Reply #32 on: December 26, 2020, 12:11:29 PM »
No, the seal is in the wrong place to seal the roller ends. Hopefully this shows what I mean:
Re: chain oilers
« Reply #33 on: December 26, 2020, 01:31:08 PM »
And those O/X seals need good lubrication with the side plates constantly rubbing on both sides of them, ideally a little & often to wash away the crud. As any experienced rider would/should know.
Re: chain oilers
« Reply #34 on: December 26, 2020, 05:04:33 PM »
No,...Hopefully this shows what I mean:
OK, thanks -- yes it does, great illustration.
Re: chain oilers
« Reply #35 on: December 28, 2020, 04:19:44 AM »
The roller rotates around the bush..., and the roller/bush interface is lubricated by chain lube.
Well, yes & no. Yes b/c the bush/roller interface will be lubed by the grease applied when first manufactured -- but no b/c once that grease leaves through the non-sealed gap between the roller and the inner plates there won't be any way to effectively get grease back in there.
Yes, chain lube can be applied to the outside -- but getting some between the roller and the bush may be doubtful-to-impossible.  :187:
(especially with centrifugal force working against such a process...)
« Last Edit: December 28, 2020, 04:25:10 AM by AvgBear »
Re: chain oilers
« Reply #36 on: December 28, 2020, 03:53:17 PM »
Exactly :047: spot on that man. 'Tis why the oiler nozzle should be 20 to the hour on the sprocket, so centrifugal force gets the oil into all the chain components.
« Last Edit: December 28, 2020, 03:59:24 PM by Paulhere »
Re: chain oilers
« Reply #37 on: December 28, 2020, 05:30:11 PM »
If workig as you describe, would it not be better without the O/Z/W/X rings (in the way) obstructing the process..?   :187:
Re: chain oilers
« Reply #38 on: December 28, 2020, 05:48:19 PM »
Don't be silly, there'd be nothing to keep the crud out.  :087:
Offline T-Rever
Re: chain oilers
« Reply #39 on: December 28, 2020, 06:14:47 PM »
My experience for what it is worth.
2012 Tiger Roadie. 18,600miles from new. I have been riding 65 years (yes I am 81), Tutoro oiler fitted,any  multigrade engine oil goes in during warmer weather, you have to thin it when the temperature falls. It does not like the winter, neither do I. I never clean my chain,I find that the crud flings off with the surplus oil. 25000 to 30000 can be had from an overlubed chain.
