Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
March 02, 2021, 04:06:57 AM
Home
Forum
Search
Members Map
Photos Gallery
Login
Register
Triumph Tiger 800 Forum
chain oilers
Print
Pages:
1
2
3
4
5
Go Down
Author
Topic: chain oilers (Read 5418 times)
tauzero
Tiger Master
Bike: Tiger 800 XRx
Re: chain oilers
Reply #30 on:
December 26, 2020, 01:29:14 AM »
There are two rubbing surfaces - the pin on the outer plates goes through the bush on the inner plates, and that friction interface is permanently lubricated by the grease sealed in by the O/Z/W/X rings. The roller rotates around the bush and the outer surface of the roller is the surface that the sprocket goes onto, and the roller/bush interface is lubricated by chain lube.
Logged
AvgBear
Tiger Jedi
Bike: '12 Venom Roadie
Re: chain oilers
Reply #31 on:
December 26, 2020, 05:42:54 AM »
Originally Posted by
tauzero
Aren't both inner & outer surfaces of the bush permanently lubricated by the grease sealed-in upon chain assembly? I.E. the outer surface of the pin, the inner surface of the bush, the outer surface of the bush, and the inner surface of the roller -- are the greased & sealed interfaces (rubbing surfaces).
The chains rollers (outer surfaces) are, then, (ideally) not rubbing surfaces and external lube may, when applied, offer a protective film and a pressure cushion to the roller sprocket interface.
Last Edit: December 26, 2020, 06:14:28 AM by AvgBear
Logged
tauzero
Tiger Master
Bike: Tiger 800 XRx
Re: chain oilers
Reply #32 on:
December 26, 2020, 12:11:29 PM »
AvgBear
No, the seal is in the wrong place to seal the roller ends. Hopefully this shows what I mean:
Logged
Paulhere
Tiger Jedi
Bike: Tiger 800 XRx
Re: chain oilers
Reply #33 on:
December 26, 2020, 01:31:08 PM »
And those O/X seals need good lubrication with the side plates constantly rubbing on both sides of them, ideally a little & often to wash away the crud. As any experienced rider would/should know.
Logged
AvgBear
Tiger Jedi
Re: chain oilers
Reply #34 on:
December 26, 2020, 05:04:33 PM »
tauzero
No,...Hopefully this shows what I mean:
OK, thanks -- yes it does, great illustration.
Logged
AvgBear
Tiger Jedi
Re: chain oilers
Reply #35 on:
December 28, 2020, 04:19:44 AM »
tauzero
The roller rotates around the bush..., and the roller/bush interface is lubricated by chain lube.
Well, yes & no. Yes b/c the bush/roller interface will be lubed by the grease applied when first manufactured -- but no b/c once that grease leaves through the non-sealed gap between the roller and the inner plates there won't be any way to effectively get grease back in there.
Yes, chain lube can be applied to the outside -- but getting some between the roller and the bush may be doubtful-to-impossible.
(especially with centrifugal force working against such a process...)
Last Edit: December 28, 2020, 04:25:10 AM by AvgBear
Logged
Paulhere
Tiger Jedi
Bike: Tiger 800 XRx
Re: chain oilers
Reply #36 on:
December 28, 2020, 03:53:17 PM »
AvgBear
Exactly
spot on that man. 'Tis why the oiler nozzle should be 20 to the hour on the sprocket, so centrifugal force gets the oil into all the chain components.
Last Edit: December 28, 2020, 03:59:24 PM by Paulhere
Logged
AvgBear
Tiger Jedi
Re: chain oilers
Reply #37 on:
December 28, 2020, 05:30:11 PM »
Paulhere
If workig as you describe, would it not be better without the O/Z/W/X rings (in the way) obstructing the process..?
Logged
Paulhere
Tiger Jedi
Bike: Tiger 800 XRx
Re: chain oilers
Reply #38 on:
December 28, 2020, 05:48:19 PM »
AvgBear
Don't be silly, there'd be nothing to keep the crud out.
Logged
T-Rever
Tiger Pro
Bike: Tiger 800 Roadie
Re: chain oilers
Reply #39 on:
December 28, 2020, 06:14:47 PM »
My experience for what it is worth.
2012 Tiger Roadie. 18,600miles from new. I have been riding 65 years (yes I am 81), Tutoro oiler fitted,any multigrade engine oil goes in during warmer weather, you have to thin it when the temperature falls. It does not like the winter, neither do I. I never clean my chain,I find that the crud flings off with the surplus oil. 25000 to 30000 can be had from an overlubed chain.
Logged
Print
Pages:
1
2
3
4
5
Go Up
chain oilers
2016 800XRt - Removing Throttle Restriction?
ECU Re-Mapping and Tuning
pjensen641
Today
at 03:21:37 AM
Review / Rate your other bikes.
On Two Wheels
93TigerBill
Today
at 01:57:05 AM
Tiger reliability
tauzero
Yesterday
at 11:02:25 PM
rox risers
samsgrandad
Yesterday
at 09:26:28 PM
Givi AF6401 Aeroflow Screen - used but excellent condition
For Sale
Dazcoates
Yesterday
at 07:15:18 PM
Givi AF6401 screen on 2017 xrt
Dazcoates
Yesterday
at 07:13:52 PM
Idle speed rising/hunting with clutch in
Misc Technical Help Required
KildareMan
Yesterday
at 04:35:59 PM
OEM Fog lamp Wattage
philmcglass
Yesterday
at 04:16:40 PM
Electronic gremlins
Djairouks
Yesterday
at 06:53:33 AM
Pulsing light/revs.
gryan39
February 28, 2021, 09:51:03 PM
