Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: raising the low version  (Read 1436 times)
Offline Marios73
  • Bike: Xrx lhr
« on: November 30, 2020, 12:01:52 PM »
Hi to all, i have the 2016 800xrx low version and i am mostly concerned about the Payload which is only 147 kg. So after a bit of searching i found out that for the front suspension only the damper rod and the springs are different compared to Normal model.
Does anyone have damper rod and springs from normal XRX for sale ( assuming that he upgraded the front forks).??
Re: raising the low version
« Reply #1 on: November 30, 2020, 12:03:33 PM »
That 147kg was an error in the user handbook
Offline Marios73
  • Bike: Xrx lhr
« Reply #2 on: November 30, 2020, 12:21:20 PM »
Unfortunately ... see my correspondence below
-----ME-------
Dear Sir
i am an owner of a Tiger 800 xrx LRH 2016 model with the Vin Number:xxxxxxxxxxxxxxx and i would like to ask which is the maximum Payload of my motorcycle. I bought it used and i don't have the owners manual. The Online manual states 222 kg but i think that this refers to the newer LRH model.
Can you please confirm.
Answer-----
Hi Marios,
Thank you for your email
I can confirm that the payload for the Tiger 800 XRX Low is 140KG due to the reduced ground clearance and suspension travel.
------ME-------------
Dear Mike.
Thank you for your prompt response.
That means that the newer version of 800 xrx low has different suspension? Because the ground clearance is the same. And the manual states 222 kg
Kind Regards
Hi Marios,
The Tiger 800 XRX-LRH from Vin 855532 has a maximum payload of 222 kg (489 lbs) due to different suspension components.
Regards
Mike
« Reply #3 on: November 30, 2020, 03:19:58 PM »
Ok, when I queried it, I was told it was an error.
Offline Marios73
  • Bike: Xrx lhr
« Reply #4 on: November 30, 2020, 04:15:07 PM »
there is something strange about it, because when i asked for the part number of the rear suspension newer version (with the 220 kg payload) they gave me this
Hi Marios,
The part number for the Tiger 800 XRx-LRH is T2058401. This can be ordered from your local Triumph dealer who will be able to advise you of the price and availability.
Regards,
and for my version the part number is the same, so something is strange!
« Reply #5 on: November 30, 2020, 04:31:14 PM »
Look at bikes used on, no bikes found????? Gets worse. Maybe it has been superseded.
https://www.fowlersparts.co.uk/parts/view/T2058401
Offline Marios73
  • Bike: Xrx lhr
« Reply #6 on: November 30, 2020, 04:39:17 PM »
« Reply #7 on: November 30, 2020, 04:41:22 PM »
Scroll up & down, it also says Bikes used on - No bikes found. Strange eh.
Offline Marios73
  • Bike: Xrx lhr
« Reply #8 on: November 30, 2020, 04:45:34 PM »
yes i entered another part from my Low version , seems that the site doenn;t have the low version parts at all
if you click the link i provided you can find most of the parts, i think it is better.
« Reply #9 on: November 30, 2020, 05:29:04 PM »
WOT site gives both the std & LRH shocks.'T2058700 std & T2058401 LRH
https://www.worldoftriumph.com/collections/100089815-0-2?type=tiger-800-xrx-from-vin-855532
My bike is stock, just trying to help, maybe somebody who's done this will be along with a better idea.
