Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
January 22, 2021, 11:53:33 AM
Home
Forum
Search
Members Map
Photos Gallery
Login
Register
Triumph Tiger 800 Forum
Bike purchae
Print
Pages:
1
2
Go Down
Author
Topic: Bike purchae (Read 2289 times)
Fazer
Tiger Pro
Bike: Tiger 800XRt
Re: Bike purchae
Reply #10 on:
December 29, 2020, 01:04:40 PM »
I haven’t experienced the issue myself but I’ve see a few postings on here and other Tiger 800 Forums about failure of the gear shift return spring.
Logged
KildareMan
Tiger Jedi
Bike: Venom Yellow 800
Re: Bike purchae
Reply #11 on:
December 29, 2020, 03:51:56 PM »
Originally Posted by
Fazer
Mainly the spring retention peg braking leaving the gear lever "down" when changing down the gears. Simple to fix the peg.
Springs were replaced early on - from late 2011, though not necessarily for breaking.
Logged
dragon88
Tiger Member
Re: Bike purchae
Reply #12 on:
December 29, 2020, 10:19:32 PM »
KildareMan
Two tabs of the sprocket nut does the job rather than the one tab.
I would suggest a top nut coming off is down to lack of preventative maintenance or not being torqued to spec.
As for start switch failures. Haven't heard that one. Are you referring to starter motor?
Tabbing 2 sides still does not work mate. Top nuts coming off are widely known and nothing to do with preventative maintenance. Factory screw up. Torque to 90nm with blue loctite solves that woe.
Start switch failures, not the starter motor. As mentioned now on V3 because of this issue. Unrepairable. Triumph gave me one for free for an upcoming trip as a spare.
Logged
Alberto_B
Tiger Pro
Bike: T800XRT '16
Re: Bike purchae
Reply #13 on:
December 29, 2020, 10:25:42 PM »
Fazer
I have recently had the gear change linkage replaced during service as it had play according to the dealer. It was about £125 iirc, on top of the service cost, and required the whole mechanism replacing as Triumph doesn't sell the individual parts. That was before I had seen the various threads on here about how some folk have managed to solve the problem. - e.g.
https://www.tiger800.co.uk/index.php/topic,22487.0.html
Fortunately I did keep the original, so if the replacement wears (currently about 8,000 miles) I will have a replacement to hand for a few £.
Logged
tauzero
Tiger Master
Bike: Tiger 800 XRx
Re: Bike purchae
Reply #14 on:
December 30, 2020, 01:20:33 AM »
dragon88
Be careful with that question mate, it offends some people who think nothing ever goes wrong with the 800. Like every bike there are some known issues but nothing that cant be resolved with relative ease. All in all they are generally very reliable. A few known issues
Start switch failures. Now on V3 and made in Germany after numerous reports of failures
Front sprocket nut comes off as tab washer just isnt enough to retain it. Easily fixed by drilling the shaft and putting a split pin in
Top triple clamp nut coming loose and flying off into the wilderness.
The stock engine crash bars have been known to snap a section off the engine case where they mount when the bike is dropped. Run Heed bars instead far better protection.
I'm curious about where these known issues are known. I can't recall any start switch failures being reported on this forum. I think there have been two or three loose front sprocket nuts. One report of top clamp nut loose - of course, it might have been serviced and not done up to 90Nm. I don't recall any of them being mentioned on the Triumph Rat Tiger section either, though I don't read that as thoroughly as here.
The most common issues that have come up here have been gearshift issues, starter motor issues, and main fuse/starter solenoid issues.
Logged
dragon88
Tiger Member
Re: Bike purchae
Reply #15 on:
December 30, 2020, 01:46:13 AM »
tauzero
My source is one of the top tech guys for Triumph in Asia. I am only relating what they see on a regular basis but additionally, our own group of Triumph riders seeing multiple instances of failures in these areas. Just passing info on, dont shoot the messenger. ;)
Logged
KildareMan
Tiger Jedi
Re: Bike purchae
Reply #16 on:
December 30, 2020, 08:30:58 AM »
dragon88
Sounds like local issues, bar possibly the switch, to me.
Tabbing two sides DOES WORK, for me at least. one side can loosen off over time. Two doesn't.
No loctite required on my 2011 top nut. It's torqued to the correct level. I'm still on my original starter switch and have heard on no other instances mentioned here, other than the usual, to most bikes, of dirt getting into the switch - nothing a good spray out can't cure.
Logged
T-Rever
Tiger Pro
Bike: Tiger 800 Roadie
Re: Bike purchae
Reply #17 on:
December 30, 2020, 03:50:50 PM »
I have had my 2012 Roadie since 2014 and 4500miles. It is now on 18600 miles, and I have had no issues to date. Changed my front sprocket for 17t at about 5000, if the nut is torqued up properly, and tabbed over, no probs. Nothing to report.Never heard of the starter switch problem.
Logged
Print
Pages:
1
2
Go Up
Bike purchae
Evotech Performance Quadlock support for 2010-2017 Tiger 800
For Sale
Ragtop
Today
at 11:43:48 AM
TigerTool Help - Access to a Tiger 900 needed
ECU Re-Mapping and Tuning
rainbow-walker
Today
at 11:17:00 AM
New seat?
Scooty
Today
at 09:50:23 AM
Megameet 2021 now 10 to 12 September 2021
2021 Tiger Mega Meet - Germany
Derchef1962
Today
at 08:08:49 AM
Clutch/Brake levers
chico
Today
at 01:30:38 AM
Is a 20mm lowering link set available?
ZShyster
Today
at 12:42:42 AM
Large Pet Carriers
Accessories and Products
Paulhere
Yesterday
at 10:05:03 PM
Starter Motor
Terry Ryan
Yesterday
at 09:57:35 PM
Another Tiger!
Admin
Yesterday
at 09:56:16 PM
Triumph Tank Bag strap needed
Bulldog293
Yesterday
at 07:16:33 PM
