Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Throttle body balancing  (Read 837 times)
Offline oNLIme
« on: December 11, 2020, 09:18:41 PM »
Just finished a comprehensive 12k service on my 2011 16k roadie.  Decided after a year of ownership it needed a thorough going over to see what has and had not been done.
In the process, I used Dealertool for the first time and thought the following might be of interest to anyone contemplating throttle body balancing.  Before I stripped down (ended up re-shimming as exhaust valve clearances were out), I ran the balance check in Dealertool and given a 2-3kpa variance across the bodies, it signalled adjust.  So at least I knew what Id be getting into...
However, along the way, I cleaned the throttle bodies, cleaned, adjusted and lubed the throttle cables and mechanism and also cleaned and lubed (PTFE) the stepper motor.  After refitting the cams and new sparks, I ran Dealertool again and this time it read balanced, so no need to adjust.  Variance was down to 1 kpa .  Tested again after refitting the airbox and new filter and got the same result.
Slightly disappointed not to also chalk up the experience of adjusting the bodies but also a bit relieved as there was plenty of other work to do.  Also demonstrates the value of a good clean and lube, which is obviously a preferable first step to turning screws.
Hope that helps someone.
Online PapaTom
Re: Throttle body balancing
« Reply #1 on: December 12, 2020, 08:43:31 AM »
Reassuring post.
