Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: OD of Spacers for Rear Wheel - Tiger 800XC 2011-2019  (Read 884 times)
Offline Nathompson1
« on: January 04, 2021, 09:08:50 PM »
Need some help here...
I am working on a build and am using the rear wheel from a Tiger 800XC (Years: 2011 - 2019).
The swing arm on the bike is wider than the swing arm of the Tiger so I need to make some new spacers.
To my question... what is the OD of the spacers on the Tiger 800XC?
I need to the dimensions to make sure the spacers seal correctly against the bearings in the wheel.
Any help you can provide would be great!!
Best,
Adam
Offline pme
  • Bike: xrx lrh 2018
Re: OD of Spacers for Rear Wheel - Tiger 800XC 2011-2019
« Reply #1 on: January 05, 2021, 09:12:01 AM »
Hi Adam
2016 xcx has a 28mm OD. If you have a good look on the oil seal you should be able find a reference number  to look up the spec for the seal.
Hope that helps
rgds
chris
Also DRZ400sm for forest tracks, previous bikes:- Honda SS50, BSA 250SS80, Yamaha RD125, Yamaha TY250, Honda CBR600, Honda Africa Twin XRV750, Kawasaki KMX200, Kawasaki KDX200, Kawasaki KLX250
Offline Nathompson1
« Reply #2 on: January 05, 2021, 03:18:40 PM »
Thanks for the quick response!
I took a quick measurement last night and it looks like something around 35 mm.
Does that sound right?
Assuming to OD would be different based off of the wheel right?
Best,
Adam
Offline pme
« Reply #3 on: January 05, 2021, 06:13:38 PM »
its a top hat shape the "brim" is 34mm,  the part into the seal is 28mm
this is the rear wheel
Offline Nathompson1
« Reply #4 on: January 05, 2021, 06:37:31 PM »
So the Silver part on the right is 34/35 mm and the black piece is 34 mm on the left and 28 mm in the middle... correct?
Best,
Adam
Offline pme
« Reply #5 on: January 06, 2021, 11:17:54 AM »
the silver part may be part of the spacer inside between the bearings?
see attached picture of what i measured
Offline D6864
  • Bike: White XC
« Reply #6 on: January 06, 2021, 03:06:19 PM »
The silver part is the left hand spacer between the sprocket carrier and the swingarm, 35mm o/d
Offline Nathompson1
« Reply #7 on: January 06, 2021, 03:13:55 PM »
Got that... what's the OD of the right hand spacer?
Something like 28 mm?
Best,
Adam
Offline Londonglide
  • Bike: xc
« Reply #8 on: January 06, 2021, 05:07:53 PM »
I've got the two original outer spacers on the desk, having replaced them with VFR Pauls Titanium ones.
The Chain side, straight spacer has an OD of 34.92mm so nominal 35mm,  and the other, mushroom shaped one for the brake side is 28mm OD at the oil seal position
Both have an ID of 20.1-20.2mm
