Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Swingarm play  (Read 1029 times)
Offline ItchyOxter
  • Bike: Tiger XR
Swingarm play
« on: January 12, 2021, 01:37:53 PM »
Finally got round to stripping the rear swingarm/linkage for cleaning and re-greasing. Bearings and seals all looked in good condition, cleaned and re-greased but upon reassembly (before fitting rear wheel) have noticed a very subtle bit of play when lifting the swingarm (nothing from side to side). Feels like a tiny bit of play at the top of the linkage which I assume will disappear when the bike takes its own weight. Anyone come across this? Bike is a roady with only 11500 miles.
Re: Swingarm play
« Reply #1 on: January 15, 2021, 05:06:26 PM »
*Originally Posted by ItchyOxter [+]
...have noticed a very subtle bit of play when lifting the swingarm.
Mr. Haynes say: "There should be no discernible movement -- no discernible freeplay."
If all fasteners checked and correctly tightened (and movement still exists?) -- then worn bearing/s exist and must be replaced.
Offline benebob
  • Bike: 13 800 ABS
Re: Swingarm play
« Reply #2 on: January 19, 2021, 01:31:03 AM »
I just took mine apart a few weeks back for the same thing.  No play at all before I started or after but I did find about 1/3 of the needles in the left side of the swingarm were completely gone so I would tend to think that you may want to go back thru and check again.  Is your play on both sides of the swingarm?
Online Londonglide
  • Bike: xc
Re: Swingarm play
« Reply #3 on: January 19, 2021, 07:56:00 AM »
Are we talking about the swinging arm individually, or the arm and linkage, or the arm, linkage and shock?
Offline romanrick
  • Bike: tiger 800xc
Re: Swingarm play
« Reply #4 on: January 19, 2021, 06:14:52 PM »
You may find it's play at the top of the shock where it's bolted to the frame which should not be a problem, as above, find exactly where the play is before spending any money.
