Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: TC disabled and Engine warning light  (Read 1767 times)
Offline centaur62
  • Bike: 2018 Tiger800XRt
Re: TC disabled and Engine warning light
« Reply #20 on: January 17, 2021, 01:28:34 PM »
The Speedometer is working, is it possible for the fault code to come up independant of the speedo ie. applying to the rear ABS sensor only or are they always linked.
Offline T800XC
« Reply #21 on: January 17, 2021, 01:46:23 PM »
*Originally Posted by centaur62 [+]
They're Always linked. It's possible there was a brief signal interruption to cause the error code and maybe you didn't notice an incorrect speedo reading.
If you have access to TigerTool, Dealertool or TuneECU you should check the ABS ECU for more sensor fault information as it should tell you more about the nature of the fault.
Online characticus
  • Bike: 2018 XRx
« Reply #22 on: January 17, 2021, 02:11:36 PM »
According to Triumph manual, P0500 fault code can be thrown from either front or rear wheel speed sensor.
Fault code: P0500
Possible Cause: Vehicle speed sensor malfunction
Action: Refer to the following ABS diagnostic trouble codes
C1611 (see Front Wheel Sensor Open Circuit/Short Circuit)
C1612 (see Front Wheel Sensor Abnormal Input/losing Contact)
C1613 (see Rear Wheel Sensor Open Circuit/Short Circuit)
C1614 (see Rear Wheel Sensor Abnormal Input/Losing Contact)
My understanding is that in this case "vehicle speed" reads as "wheel speed".
Offline centaur62
« Reply #23 on: January 17, 2021, 02:27:18 PM »
No access to DealerTool etc. Have to find a competant dealer.
Many thanks to everyone so far with this issue.
Offline centaur62
« Reply #24 on: January 17, 2021, 03:03:48 PM »
As an absolute beginner at something like this what analytical kit would you recommend I get and what software would I need to download, perhaps a link to same.
« Reply #25 on: January 17, 2021, 03:09:31 PM »
Probably too late for this event, but there is a method to identify the (majority) of fault codes even if you don't have Tigertool and a cable.
https://www.tiger800.co.uk/index.php/topic,14967.0.html
I specifically put '(majority)' of fault codes because in my case I only had the same 'P' codes as you from the button process and also on the then current version of Tigertool V2. Then through the help of posting my progress on here T800XC was able to confirm there was a bug he was aware of in that version and supplied me his beta version of the pre-released V2.5 and this did in fact then give me the previously unreported C1661/C1662 codes and via that fault code in the workshop manual confirm that the over-voltage (checked because of another members comment) would indeed throw up all the relevant fault codes I had.
https://www.tiger800.co.uk/index.php/topic,24031.0.html
... in conjunction with ...
https://www.tiger800.co.uk/index.php/topic,22590.10.html
It really would pay (at a fraction of an hours dealer labour charge) to obtain a Tigertool compatible lead as it would have possibly given you further helpful codes as it did me. I don't think anyone here who has wouldn't confirm how easy to use and invaluable it is ... and now also the improved Tigertool V3. :028:
These modern bikes are pretty reliable but when the electrics/electronics play up it rarely appears to be a straight forward diagnosis. :003:
Offline centaur62
« Reply #26 on: January 17, 2021, 04:11:55 PM »
Lead ordered, once here I'll get my son to help download Tigertool V3.
For me this is a serious learning curve but fun too.
