Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
March 03, 2021, 04:42:16 AM
Home
Forum
Search
Members Map
Photos Gallery
Login
Register
Triumph Tiger 800 Forum
Suspension and Chassis Set-up and Mods
fitting later model WP forks
Print
Pages: [
1
2
Go Down
Author
Topic: fitting later model WP forks (Read 897 times)
Poacher67
Tiger Member
Bike: 2013 800 XC ABS
on:
January 23, 2021, 11:31:38 PM »
Does anybody know whether the late model XCA WP fork legs fit the early model XC yokes (a.k.a. triple trees) or would I have to fit the later yokes too and is there anything else that wouldn't fit/line up ?.. Best wishes to all.
Logged
Aussie Tiger
Tiger Pro
Bike: 900 Rally Pro
Re: fitting later model WP forks
Reply #1 on:
January 24, 2021, 07:48:51 AM »
Both upper and lower yokes have the same part numbers for XC models across all 3 gens. All Tiger 800s (Road and XC) have the same brake rotors. Probably the only thing to check will be the mounting points for the brake calliper and from what I can tell there may be no problem there either. While the callipers have different part numbers across the gens this is perhaps just due to colour - gold/black but also because Gen 3 are Brembo. However the WP forks themselves, which incorporate the calliper mounts, have the same part numbers in Gen 2 and Gen 3. Everything points to Gen 1 callipers fitting OK but you perhaps should check that to be sure.
Logged
Londonglide
Tiger Pro
Bike: xc
Reply #2 on:
January 24, 2021, 09:00:13 AM »
I fitted a set of Late model Brembo's to my 2012Xc, and they bolted straight on, so no problem there.
The Brembos contact the disc slightly higher, so if you have lipped discs, it might affect the braking, but I only have 14K on mine, so the discs were still pretty flat.
Logged
Ragtop
Tiger Member
Bike: ‘16 800 XCA
Reply #3 on:
January 24, 2021, 01:04:51 PM »
Londonglide did you feel much of an improvement going from the Nissin to the Brembo calipers?
Logged
Londonglide
Tiger Pro
Bike: xc
Reply #4 on:
January 24, 2021, 02:13:11 PM »
I think there some difference in braking ability, they seem a little more responsive, but they are not fully bedded in.
I fitted new pads of the same type as the ones in my Nissin Callipers.
I think they will be an improvement when fully seated, but I only have a few hundred miles on since changing them.
I will say that they were in nice condition compared to my originals, and much newer, although I had overhauled my originals recently, the Brembos were a steal from an auction site.
I prefer the way the Brembo's are made, with the pistons having what appears to be some form of coating, possibly ceramic or anodised?
They were very smooth in the bores when I checked them, and I like the way the locating pin is held in by clips, not screwed in.
Overall I think they would only make sense if you were in need of replacement callipers, or they came up at a good price.
My experience with the 1995 Carb Tiger I had was the older parts become more difficult to source, if like me you keep bikes for a long time, it is nice to know they can be retrofitted.
And they are black, which I prefer to the gold of the originals.
Logged
Poacher67
Tiger Member
Reply #5 on:
January 24, 2021, 11:11:26 PM »
Originally Posted by
Aussie Tiger
Thanks very much for that Aussie Tiger, a really comprehensive answer which reassures me that apart from the possible caliper mounting issue the WP forks will very likely be a fit for my 2013 XC - I've been thinking about it for a while, mainly due to the WP forks being adjustable but I don't know whether it's a sensible or cost effective modification because I don't know if they perform markedly better overall than the originals ?..
Logged
Poacher67
Tiger Member
Reply #6 on:
January 24, 2021, 11:29:50 PM »
Londonglide
Thanks Londonglide - Looks like this solves the caliper mounting question, although if your new Brembo calipers ride a little higher on the disc with original forks maybe Nissin calipers will ride a little low when used with WP forks ? - I suppose it won't matter too much as long as the friction material of the pads still runs completely on the friction area of the discs..
Logged
Aussie Tiger
Tiger Pro
Bike: 900 Rally Pro
Reply #7 on:
January 25, 2021, 04:56:10 AM »
Poacher67
I thought the WP forks on my XCX were excellent and frankly was surprised they’d been swapped for Showa on the 900 as I felt they were perfect. Then I was further surprised to find that the Showa are indeed better. The problem with the Tiger is that it’s been so unbelievably good through each generation yet somehow Triumph has managed to improve on what was already pretty perfect. The WP will be better but I suspect not by a huge amount. What you really gain is adjustability. For what it’s worth the fully adjustable WPs on my 800 and the fully adjustable Showa on my 900 have remained on factory settings......
Logged
Londonglide
Tiger Pro
Bike: xc
Reply #8 on:
January 25, 2021, 08:03:07 AM »
Poacher67
Its the shape of the pads within the calliper.
The Brembos are much slimmer, and if you look at them side by side, it seems the Nissin has a larger footprint, as it were.
If you are fitting the original callipers with the original wheel/disc combo, but with WP forks, I am confident it will put the pads in the same place as they were before, in relation to the discs.
Logged
Poacher67
Tiger Member
Reply #9 on:
January 25, 2021, 07:43:21 PM »
Londonglide
Ah, I see what you mean..
Logged
Print
Pages: [
1
2
Go Up
Cannot get bike into Neutral with engine running
Misc Technical Help Required
trawler
Today
at 03:36:12 AM
Ride height
benx
Today
at 01:49:40 AM
Battery problem, bike does not start always
Alan215
Today
at 12:46:19 AM
Where to fit Sat Nav on new 2018 Tiger 800
A_Beer_Too_Far
Yesterday
at 11:22:43 PM
Got the new baby home! :)
RTV
Yesterday
at 09:46:17 PM
A_Beer_Too_Far says Hello From Oregon USA
New Members
gordybrock
Yesterday
at 09:14:12 PM
Review / Rate your other bikes.
On Two Wheels
jeffa
Yesterday
at 08:31:21 PM
What to check on a used Tiger?
Tigermainia
Yesterday
at 07:36:17 PM
Condensation in the TFT screen
Tigermainia
Yesterday
at 07:32:37 PM
Newbie Intro
New Members
Tigermainia
Yesterday
at 07:29:51 PM
