Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Comfort seat / low comfort seat for Tiger 900?  (Read 656 times)
Offline ProfThunder
« on: January 25, 2021, 02:35:16 PM »
I saw that there is a comfort seat and a low comfort seat for the Tiger 900. I thought about possibly getting the low one for my Rally Pro. Don't know whether 2cm lower would make much difference. Wondered if anyone has tried it and whether its any more comfortable than the stock seat? Also does anyone know if this will still be a heated seat or not. Its doesn't say on the Triumph site.
Tiger 900 Rally Pro (2020)
Offline Jarse
  • Bike: Rally Pro
Re: Comfort seat / low comfort seat for Tiger 900?
« Reply #1 on: January 25, 2021, 06:35:53 PM »
I tried the standard low seat on mine but it was desperately uncomfortable. The sides dug in especially when your feet are down.
I had a comfort low on my Explorer and it was excellent, thankfully I’m tall enough for the 900 RP.
Note standard low is not heated either.
Offline Aussie Tiger
« Reply #2 on: January 25, 2021, 07:24:36 PM »
The low seat for the 900 is hard as a rock. I think a better option is actually to lower the bike - depending of course on the type of off-road you intend doing. Drop the forks through, buy a linkage kit and new shorter side stand and the cost will be similar to a low seat.
Advantages are many. You retain full suspension travel, you keep your comfortable heated seat, you’re not sitting as much ‘in’ the bike as with a low seat and you can restore it to full height for resale (or not - and be selling to a broader market).
The only disadvantage is slight loss of ground clearance (unlike a factory low where also loose travel).
« Last Edit: January 25, 2021, 07:28:37 PM by Aussie Tiger »
Offline ProfThunder
« Reply #3 on: January 25, 2021, 08:03:54 PM »
Thanks. In view of these replies I think I’ll just stay with the same seat and height.
Offline fac191
  • Bike: Super Tenere ES
« Reply #4 on: January 26, 2021, 09:30:07 AM »
Lower seat less foam less comfortable
Offline posty
  • Posty
  • Bike: Tiger 800 XRX 16
« Reply #5 on: January 26, 2021, 10:50:45 AM »
Yes its similar story on 800 Tigers - As I'm a shortarse, I had my 2016 800 XRX lowered by Triumph with new dogbone links after a test ride before I bought the bike - they also fitted a low seat, which I thought was fine initially but after some longer rides, it is hard on yer bum after an hour or so - I refitted the original seat, which is much more comfortable with little difference to seat height
