Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Can I use XCA forks on my XCX?  (Read 387 times)
Offline sullivs
  • Bike: 2018 Tiger XCX
« on: January 27, 2021, 09:29:18 PM »
I'm replacing a bent fork on my '18 XCX and came across a used set of forks from a '16 XCA with the electric dampening adjustment. I don't know what that does exactly. So my question is... can I bolt them on and simply not use the electric adjustment? I thinking another option would be to swap out the internals (as long as they are not damaged) or remove the electric bits?
Your thoughts?
Thank you,
Steve
1975 Trident
2017 Street Cup
2018 Tiger XCX
Offline Aussie Tiger
  • Bike: 900 Rally Pro
Re: Can I use XCA forks on my XCX?
« Reply #1 on: January 28, 2021, 06:48:10 AM »
Sounds like youve found forks from an Explorer. Check the outside diameter to see if theyll fit in the yokes - Im assuming your XCX is an 800. However, you will not be able to use your 800 wheel or brakes.
Offline sullivs
« Reply #2 on: January 28, 2021, 03:03:35 PM »
Good point.  I looked into it further, and the seller has the speed sensor wire still attached to the left fork leg.  He mistakenly thought it was some kind of electronic adjuster.
So I appreciate you questioning it.  That helped me learn a little more about it.
Thanks again!
Steve
1975 Trident
2017 Street Cup
2018 Tiger XCX
