Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Spare connector post rebuild 2015 xcx 800  (Read 616 times)
Offline Craig9242
  • Bike: Tiger xcx
« on: February 04, 2021, 09:14:46 PM »
Hi. I have stripped my bike down to give it a deep clean. When rebuilding i seem to have a spare connector near the abs unit/ under the air filter intake just in front of the ecu. I will try to attach a couple of photos. Is this supposed to be spare because i can't for the life of me see where it fits
Thanks in advance
Craig
Offline dragon88
Re: Spare connector post rebuild 2015 xcx 800
« Reply #1 on: February 04, 2021, 11:43:54 PM »
If it was a spare it would have a blanking plug in it mate. Looks like an air temp sensor plug. Check your airbox
Offline Craig9242
  • Bike: Tiger xcx
« Reply #2 on: February 05, 2021, 06:31:34 PM »
Thanks but i have checked airbox and there doesnt appear to be any connectors close enough
Offline Craig9242
  • Bike: Tiger xcx
« Reply #3 on: February 05, 2021, 10:38:33 PM »
I checked the wiring diagram in haynes manaul yellow and red cable and brown and pink. Shows it connected to the purge valve. Do the 2015 xcx have purge valves or is this now a spare connector. Thanks again
« Reply #4 on: February 05, 2021, 10:55:28 PM »
*Originally Posted by Craig9242 [+]
.... connected to the purge valve. Do the 2015 xcx have purge valves or is this now a spare connector.
You're fine .... it is for the 'evaporative loss control system' for certain markets, not the UK.  :028:
Item 7 would connect to it ...
https://www.fowlersparts.co.uk/parts/5596944/tiger-800-xcx-from-vin-674842/evaporative-loss-control-system
Offline Craig9242
  • Bike: Tiger xcx
« Reply #5 on: February 05, 2021, 11:29:07 PM »
Thanks steve that confirms it , had just found the evap system in the manual👍. By the way arte et marte , gods Corps. I did 25 years👍
Offline TIger Lad
  • Bike: Tiger 900 GT PRO
« Reply #6 on: February 06, 2021, 12:30:13 PM »
FYI. when dismantling anything I  find it use full take a photo on my phone especially when i am  not going to reassemble for a few days.
Offline Craig9242
  • Bike: Tiger xcx
« Reply #7 on: February 08, 2021, 12:07:41 PM »
Good shout. I think this connector was tucked away so didn't realise when i dismantled. Also when i thought about it i looked at the colours on the wiring diagram which then backed up the other comments ref the eavp system
