Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
February 25, 2021, 02:08:11 PM
Home
Forum
Search
Members Map
Photos Gallery
Login
Register
Triumph Tiger 800 Forum
Downshifting to 3rd whilst coming up to the traffic lights - engine shut down
Print
Pages: [
1
2
Go Down
Author
Topic: Downshifting to 3rd whilst coming up to the traffic lights - engine shut down (Read 694 times)
kokkios
Tiger Master
Bike: 2016 Tiger800XRT
on:
February 15, 2021, 06:03:27 AM »
Well that's a first one for me. Bike is a 2016 with 48000km.
I remember seeing this problem before but on first gen Tigers(?). Did a quick search now but have to investigate further when i get back home from work.
Could unbalanced throttle bodies cause this? After having the valve clearances adjusted by my mechanic a few months back i noticed vibration on the handlebars that made my hands go numb so i checked using the Tigertool. And yes the throttle bodies are unbalanced.
Have a great week everybody
Logged
Tigermainia
Tiger Jedi
Bike: '18 XRt
Re: Downshifting to 3rd whilst coming up to the traffic lights - engine shut down
Reply #1 on:
February 15, 2021, 09:55:07 AM »
Happens on newer models as well, my '18 XRt suffered as well (from new) have described it on here some time ago. Had it 'sorted' under warranty but still suspect occasionally!!!!
Logged
From '61>present - '57 BSA C12, RE C/Sports, '59 Tiger 110, '61 T120R, '57 BMW R50, '76 GT185, '69 T120, KE 175, BMW R75, GSX750, FJ1200, XJR1300, FZ1000, '05 Sprint1050 & '08 Str Triple, Sprint1050, Sp/triple, Sprint1050, SprintGT, Trophy 1215, Speedtriple & '12 Bonne, '15 XRx,'18 XRt, Trident 660
kokkios
Tiger Master
Reply #2 on:
February 15, 2021, 10:36:46 AM »
will look for your post.
In my case it must be some kind of switch since it happened for the first time after 50K km. Maybe the side-stand or the kill switch? Strange
Logged
Bwana
Tiger Cub
Bike: 14 Tiger 800
Reply #3 on:
February 15, 2021, 07:29:17 PM »
My Mechanic told me to watch out for that when the valves wear they get tight... Can you verify if you've had them adjusted to spec or more "Open"? He adjusted my intakes to middle and exhaust on open side of spec. That was just before I parked it for the winter.
Logged
AvgBear
Tiger Jedi
Bike: '12 Venom Roadie
Reply #4 on:
February 16, 2021, 03:53:05 AM »
Originally Posted by
Bwana
Whilst your mechanic was on-target when mentioning valve adjustment technique, I think he may've erred if you think he advised that insufficient valve clearance will, as the OP described in his query, cause an unsuspected engine shutdown?
My thoughts are more in the realm of some stray voltage signal (or intermittent lack of...) causing the ECU to shut-off (temporarily)?
Logged
kokkios
Tiger Master
Reply #5 on:
February 16, 2021, 12:24:36 PM »
I really dont know details on how exactly the valves were adjusted. Hope it doesn't happen again. If it does i will have to act on it.
Dont know if this is connected but also noticed the day it happened that gear shift lever feels looser somehow
Logged
Stevie.P
Tiger Jedi
'Arte et Marte'
Bike: 2015 Tiger XRt
Reply #6 on:
February 16, 2021, 12:28:24 PM »
kokkios
.... i checked using the Tigertool. And yes the throttle bodies are unbalanced.
As you have Tigertool what 'Tune No.' is loaded.
My 2015 XRt was last updated around Sept 2016 but didn't appear to have any newer update on the 2nd (Sept 17) or 3rd (Sept 18) official Triumph service.
There was a few reports of similar symptoms early on with gen 2 bikes, mine included (and a few gen 3 reports) but when I mentioned it at the 6k service I was informed that the ECU update would cure it. Sceptical as I was that I was being fobbed off it did turn out something did occur as I never had the issue again (4.5yrs no issue).
https://www.tiger800.co.uk/index.php/topic,17271.0.html
https://www.tiger800.co.uk/index.php/topic,25406.msg281249.html#msg281249
https://www.tiger800.co.uk/index.php/topic,19875.0.html
Logged
kokkios
Tiger Master
Reply #7 on:
February 16, 2021, 01:55:16 PM »
Appears to be the same tune as yours Stevie. I have the Arrow pipe on. Also during last service the throttle body rubber seals were changed because they developed cracks.
Logged
Stevie.P
Tiger Jedi
'Arte et Marte'
Reply #8 on:
February 16, 2021, 02:34:35 PM »
Although showing as 'unbalanced' it isn't very much variation, I don't think it would have very much effect in the engine stalling.
Is that with the engine just started up specifically to use Tigertool or after a run when all at working temperature, it does have an effect.
This was the first time I ever used Tigertool and I only ran the bike to see how it worked. I had a comment that those readings appeared low.
However here I used Tigertool after I rode it first to get it up to full temperature.
Logged
kokkios
Tiger Master
Reply #9 on:
February 16, 2021, 02:43:48 PM »
61-60-58 immediately when started from cold
63-62-61 after it reached 3 bars
Logged
Print
Pages: [
1
2
Go Up
Mitas E07+ for 800XC - Bias vs Radial
Tyres and Wheels
Q
Today
at 09:30:20 AM
When will we be able to ride
On Two Wheels
RTV
Today
at 09:24:55 AM
Reduce Throttle Pull on Throttle by Wire
K1W1
Today
at 06:09:19 AM
Trident 660
Djairouks
Yesterday
at 09:34:33 PM
Got the new baby home! :)
RTV
Yesterday
at 08:13:46 PM
Recommendations for a 30k miles bike
RTV
Yesterday
at 08:08:03 PM
Triumph LED indicators
For Sale
northern lad
Yesterday
at 08:06:31 PM
Tiger 900 turn signal dissassembly
krokodil
Yesterday
at 03:35:40 PM
Madstad + Veo Vince + Triumph Machined Levers
For Sale
ronaldo
Yesterday
at 02:38:27 PM
Tiger 800 Engine Covers
peterjfox69
February 23, 2021, 08:19:43 PM
