Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Startup after long period  (Read 436 times)
Offline Thazza66
« on: February 17, 2021, 12:14:06 PM »
My bikes has been laid up in Spain during lockdown and by the time I get over there to use it again it's going to be 1 1/2 to 2 years since it was started. What is the best way to go about getting it going again after I've charged the battery. Should I start it up then change the oil or should I change the oil without even firing up. Any other things I should be wary of?
Online Grumps
  • Bike: 2018 800 Xca
Re: Startup after long period
« Reply #1 on: February 17, 2021, 02:51:01 PM »
Petrol will need changing.
« Reply #2 on: February 17, 2021, 04:23:55 PM »
Battery will be shot.
Did it have fresh oil in when it was stored?
« Last Edit: February 17, 2021, 04:26:39 PM by Paulhere »
Offline Tenequip
  • Bike: Tiger 800 XCx
« Reply #3 on: February 18, 2021, 02:07:05 AM »
Suggest you drain the fuel & replace with fresh high test fuel, before attempting to start the bike. The oil should also be changed, because it is contaminated. I would suggest you change the oil after the initial start and the motor has come up to operating temperature. This should eliminated as much of the contamination as possible. Cold oil will no drain very well at all and leave the contaminates in the engine.
Good luck!
