Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Engine management light on after flat battery  (Read 854 times)
Re: Engine management light on after flat battery
« Reply #10 on: February 20, 2021, 11:55:46 AM »
Yes it has to be full cycles let it cool down between each.
This might help.
https://www.aberdeenbikers.co.uk/motorcycle-charging-system-diagnosis-checks/
Offline Alan215
  • Bike: Triumph tiger
« Reply #11 on: February 20, 2021, 03:50:22 PM »
So just finished the 3rd cycle and went to start it again and it would not start so think getting somewhere (only try to narrow it down before having it plugged in 3/3/21) so just checking prices on stuff that link by the way is great so is it a stater or alternator
« Reply #12 on: February 20, 2021, 04:05:34 PM »
*Originally Posted by Alan215 [+]
Depends on model  :492:
https://www.fowlersparts.co.uk/parts/view/T1300043
https://www.fowlersparts.co.uk/parts/view/T1305965
Offline Alan215
« Reply #13 on: February 20, 2021, 04:23:08 PM »
[removed by auto profanity filter] still going to b best part of 500 fitted
« Reply #14 on: February 20, 2021, 05:16:14 PM »
It could still be something simple, be hopeful.
How old & how many miles? Any extra elec gizmo's? Only asking 'cos never had one fail......yet.
Offline Alan215
« Reply #15 on: February 20, 2021, 10:16:09 PM »
Hello its 2014 tiger 800 abs no extra electrical fitted 7500 miles but posted on here before about a rattle told it was normal but reading on here about rattling on the stator when doing the heat cycles it rattles on tick over but at 2000 rpm it stops to me this is not normal
Offline TigerNige
« Reply #16 on: February 21, 2021, 04:41:08 PM »
Battery voltage when running should be around 14v. When my battery went (actual battery died and voltage colapsed) I had the engine management light came up, had it reset by mechanic rather than the 3 cycles, as I was going away. On the other hand when my regulator went, it did cause the stator to rattle. I replaced my regulator for a genuine. The alternator on the early tigers have a very high output. There are a lot of "look alike " replacements on the market, but many don't have the capacity to deal with the tigers output.  My bike 2012 Tiger road.
Offline TigerNige
« Reply #17 on: February 21, 2021, 04:44:12 PM »
The charging system relies on the regulator disposing of excess power as heat. Unfortunately less extras mean more work for the regulator. My battery failure and regulator failure were separate incidents. Bike has done nearly 40K (miles)
Offline Alan215
« Reply #18 on: February 21, 2021, 07:14:50 PM »
Hello again can the rr and battery b tested off the bike to see if they have failed ordered new battery and fitted new rr but still think its not changing so would like to test old ones
Offline Alan215
« Reply #19 on: February 22, 2021, 06:15:33 PM »
Hello another update definitely the stator been to the garage and told it was definitely this dropping it in tomorrow hes going to test the old rr and the battery ask him to look into the rattle that has been there since Ive had it will update again when done
