Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
February 27, 2021, 03:27:08 PM
Home
Forum
Search
Members Map
Photos Gallery
Login
Register
Triumph Tiger 800 Forum
Reduce Throttle Pull on Throttle by Wire
Print
Pages: [
1
2
Go Down
Author
Topic: Reduce Throttle Pull on Throttle by Wire (Read 738 times)
0 Members and 3 Guests are viewing this topic.
mcman56
Tiger Cub
Bike: 2018 XRx Low
on:
February 21, 2021, 01:22:09 AM »
My new to me 2018 Tiger requires more force to turn the throttle than my old GSX1250. Is there a way to reduce the force needed? I assume the electronic unit has a spring inside. Can you get it apart and change the spring? Or can the electronic unit be swapped out?
Logged
barry.t100sr
Tiger Member
Bike: Tiger 800 XR
Re: Reduce Throttle Pull on Throttle by Wire
Reply #1 on:
February 21, 2021, 08:42:36 AM »
I think there is something wrong with it Mcman. Most ride-by-wire twist grips have a very light action, some of us find it a bit too light on bumpy roads.
Does it need lubrication ?
Logged
Two Tents
1965 T100SR
1991 Trophy 1200
2016 Tiger 800XR
Stevie.P
Tiger Jedi
'Arte et Marte'
Bike: 2015 Tiger XRt
Reply #2 on:
February 21, 2021, 11:44:38 AM »
Originally Posted by
mcman56
Never heard of anyone here having an issue with the FBW throttle being stiff. In the very early days of FBW I recall some riders, after decades of cable throttles, feeling the throttle was far too light and there was a special grease suggested/recommended (even in a bike magazine article I read) to use on the throttle tube that added a bit of resistance to the motion. I guess a very light coat of some sort of waterproof (silicon?) grease on the throttle tube might help?
Logged
crispey
Tiger Member
Bike: tiger 800 thrux
Reply #3 on:
February 21, 2021, 03:53:51 PM »
Is it springing back ok? if not are you sure the throttle grip isn't rubbing against the instrument cluster?
Logged
mcman56
Tiger Cub
Bike: 2018 XRx Low
Reply #4 on:
February 21, 2021, 04:53:28 PM »
It could be that what I'm feeling is more of an ergonomic issue than force. (I have beat up forearms). I'll try repositioning the bars. Can you put standard aftermarket bars on these bikes? I noticed that the throttle tube does not want to slide off of the bar. I can see a couple of wires in the tube and part of the handlebar end is cut away.
Logged
boldie
Tiger Member
Bike: 2020 Plate XRt
Reply #5 on:
February 23, 2021, 07:39:39 PM »
Mine felt much stronger than expected too, quite uncomfortable after an hour or so. Grip puppies are your friend, fixed it for me.
Logged
mcman56
Tiger Cub
Bike: 2018 XRx Low
Reply #6 on:
February 24, 2021, 02:17:56 AM »
Could it be that earlier models came with a softer throttle mechanism? When did the ride by wire first come on the tiger or even other models?
Logged
Woody800
Tiger Cub
Bike: 800 XCx
Reply #7 on:
February 24, 2021, 07:03:20 AM »
Are you sure nothing is interfering with the end on the throttle tube? E.g. hand guards not properly fitted or poorly installed heated grips.
Logged
mcman56
Tiger Cub
Bike: 2018 XRx Low
Reply #8 on:
February 24, 2021, 11:59:11 PM »
It is just spring pressure. Not real stiff just stiffer than I would like and stiff enough that I can't see anyone complaining. I see earlier models came with the e throttle built into the switch gear. This one has a separate unit, maybe because of heated grips. Could the tension be different?
Logged
K1W1
Tiger Jedi
Bike: XRX
Reply #9 on:
February 25, 2021, 06:09:19 AM »
RBW Tigers came with the 2015 update.
Logged
Print
Pages: [
1
2
Go Up
Tiger 900 Basic 2020 -Wiring diagram
bybecker
Today
at 02:11:21 PM
REGINA MAINTENANCE FREE CHAIN
bybecker
Today
at 01:56:24 PM
Gone over to the dark side.
On Two Wheels
Mav
Today
at 12:59:46 PM
Got the new baby home! :)
RTV
Today
at 09:34:45 AM
Ugly ticking sound from engine, 2013 Tiger 800 XC
Rauno_N
Yesterday
at 10:37:08 PM
Hi from atuttogas
New Members
TIger Lad
Yesterday
at 10:03:39 PM
Madstad + Veo Vince + Triumph Machined Levers
For Sale
Despina
Yesterday
at 09:32:43 PM
Electronic gremlins
Misc Technical Help Required
Djairouks
Yesterday
at 02:56:34 PM
Givi topcase plate M9B/M9A
Accessories and Products
OHRider
Yesterday
at 12:19:16 PM
When will we be able to ride
On Two Wheels
Paulhere
Yesterday
at 11:54:49 AM
