Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: ABS Sensor rubbing ABS ring  (Read 675 times)
Offline pennpeel
  • Bike: Triumph 800 xc
« on: February 21, 2021, 05:50:37 PM »
I took the swing arm off my Tiger 800 xc to grease the bearings and change the rubbing strip, all went well got everything back together ok until i spun the rear wheel and I could hear a squealing noise, it look like the tip of the ABS sensor is rubbing on the abs ring. It wasnt doing it before.
I havn't time now to look at it further this weekend, so its a job for next weekend, appreciate any thoughts, wheel is spinning ok I did take the rubber cushes out to check there condition, I have removed the sensor to remove the swing arm, but not much else.  As usual appreciate an help.  Really enjoying doing jobs myself aside from saving a bit of money, but not when I have problems lol
Re: ABS Sensor rubbing ABS ring
« Reply #1 on: February 21, 2021, 06:56:33 PM »
Check the position of washer # 21, it acts as a spacer.
« Reply #2 on: February 21, 2021, 07:13:13 PM »
Check the position of washer # 21, it acts as a spacer. ....
 :0461: Most likely on your garage floor ... or wherever you unscrewed the sensor. You can use a suitable sized ordinary thin washer if you don't find it, you need a gap of 0.1 - 0.5mm.  :028:
Offline diggerled
  • Bike: 2012 Tiger 800XC
« Reply #3 on: February 21, 2021, 08:04:39 PM »
You cannot win by making your neighbor lose.
Offline mcinlb
  • Bike: 2020 Tiger 900GT
« Reply #4 on: February 22, 2021, 08:46:21 AM »
Yes, washer on the wrong side of the sensor, DAMHIK..... :001: :001:
Offline pennpeel
« Reply #5 on: February 22, 2021, 06:03:27 PM »
 oops!
Thankyou as ever, just been in the garage and found a rusty washer, lying on the floor near to where the  Tiger was when I was working on it even though I had a white sheet down. I'll put it in and measure the gap for extra piece of mind.
Once again thanks! I wouldn't have attempted half of what I've done if it hadn't been for you guys and girls on the forum  :002:
Offline posty
  • Posty
  • Bike: Tiger 800 XRX 16
« Reply #6 on: February 23, 2021, 09:15:40 AM »
Yep - hands up I made the same mistake after a service - natural to assume the washer goes under the screw head but not this one!
Offline SOHUTAA
  • Bike: T800 Xcx 2016
« Reply #7 on: February 23, 2021, 12:14:17 PM »
A l'avant, concernant cette rondelle, c'est exactement la mme chose . . .
Offline stevedo
  • Bike: 800XC
« Reply #8 on: February 25, 2021, 05:46:34 PM »
If you do manage to lose your spacer or find that you have to re-shim it's possible to buy stainless replacements here: https://www.accu.co.uk/en/704-shim-washers#elasticsearch_id_feature_996434=996434_758&id_elasticsearch_category=704&orderby=ranking&orderway=asc
You can buy thicknesses between 0.1mm and 1mm.
They also have a plethora of nuts and bolts for every moto project :-)
PS I am in no way affiliated with this company.
Orange 800xc ABS travelling around the world. Currently in Argentina. www.tiger800rtw.com or https://www.facebook.com/Tiger800RTW/
