Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Mitas E07+ for 800XC - Bias vs Radial  (Read 586 times)
Offline TigerMan800XC
  • Bike: Tiger 800 XC
« on: February 24, 2021, 02:33:09 AM »
Hi All,
I have searched the internet and this site, but cannot find exactly what I need to know. Please help.
I am considering the Mitas E07+ for my 800XC. They are Bias Ply tyres.  E07+  90/90B21 + 150/70B17.
Will they be OK as the spec calls for a Radial rear tyre?
And anything else I should know about the Mitas e07+
Re: Mitas E07+ for 800XC - Bias vs Radial
« Reply #1 on: February 24, 2021, 05:44:40 PM »
*Originally Posted by TigerMan800XC [+]
Well, I think the jury is still out on that one?  :187:
To be sure, in the riders manual that comes with the bike, Triumphs reccos the tires that should be used -- those listed are, for-sure, OK.
There's been lots of discussion on the Forum about the radial/bias pros/cons -- but, the fact that new Triumphs still come from the factory with (some) bias ply tires mounted must mean that they're OK?  :187:
If/when you mount the Mitas E07+ -- you'll be the knowledgeable one...l  :002:
You're welcome
Offline 93TigerBill
« Reply #2 on: February 24, 2021, 11:11:00 PM »
[Not Another Tyre Thread!!]
This reply sort-of OT....
When I acquired my '12 800XCX it was fitted with the Mitas E07's.
Found them 'squirrelly' on tar, and even tho' only half-worn, swapped them for a pair of Michelin Anakee Adventures - transformed the 'bike. Amazing grip on tar, wet or dry.
More than adequate for me on 'dirt' roads, confidence inspiring.
My .02c.
'93 Tiger 885; '12 Tiger 800XC
IBA #45911; FarRider #89
Offline Q
  • Bike: 800 XCA
« Reply #3 on: February 25, 2021, 09:30:20 AM »
been running the Dunlop Trailmax Mission tyres now for approx 6,000kms - IMO they might well be the perfect 50/50 tyres - long-wear, decent road/off-road manners and reasonably quiet
only downsides are that you should not be stupid in the wet with them (very hard compound on rear tyre for long-wear) and they don't clean heavy mud due to small spaces between the blocks - actually grooves would be a better description because even though these look like road tyres at a quick glance, I think they will match if not better the 07's for dirt road performance
« Last Edit: February 25, 2021, 09:32:05 AM by Q »
Offline dragon88
« Reply #4 on: February 25, 2021, 11:39:26 PM »
You should check out the Motoz Tractionator GPS. Better than the Mitas.
