Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Electronic gremlins  (Read 947 times)
Offline Djairouks
Electronic gremlins
« on: February 26, 2021, 12:23:30 PM »
Today I was riding on the highway and first the speed regulator didn't want to engage at all and then I got power losses at 140kmh !!!
This is pretty worrying, anyone had this happen on a gen 3 ?
Offline healdem
  • ....has a fluffy tube
  • Bike: 2011 Tiger 800
Re: Electronic gremlins
« Reply #1 on: February 26, 2021, 01:19:21 PM »
id want to check power
check the voltage whilst running
if its not in the usual 14 to 14.5v range then id want to go through the usual
check battery is OK
check the rectifier
check the alternator
...and porobaby in that order.
Offline Djairouks
« Reply #2 on: February 26, 2021, 02:56:34 PM »
check battery is OK
check the rectifier
Yes that's what I immediately checked, battery is fine I've been riding for the last 3 days, voltages seem good to, but gradually the cruise control would sometime engage sometimes not in the last days, thought it to be an issue of cold bike mornings.
I've also noticed that changing the driving mode during riding is impossible, letting the throttle go to 0 does not validate the selection, but if I turn the engine off and change mode, it works...
I think it's either the throttle having problems or somehow a mapping issue.
I'm not taking any chances it's at the dealer, they said they think mapping is the culprit, will give updates when they'll manage to check it.
Online chuckxc
« Reply #3 on: March 01, 2021, 02:20:14 AM »
I recall testing the upper limit of the cruise control and if I remember correctly, it automatically cuts out at around 160km/hr. You might have possibly  had this happen.
Offline Djairouks
« Reply #4 on: March 01, 2021, 06:53:33 AM »
No I was between 130-140kmh and anyway it refused to engage even at lower speeds, mechanic called me shortly after my visit and told me, that it's apparently the button cluster being the culprit.
Offline Djairouks
« Reply #5 on: March 07, 2021, 01:39:06 PM »
So I picked up the bike friday, left button cluster replaced under warranty, no more sticky buttons,
but after going home engaging the cruise control, today again it does not work anymore...
Hope this won't be one of those issue that goes on forever !
Offline Thripster
« Reply #6 on: March 13, 2021, 05:56:08 AM »
Just a guess but, given what happens when the microswitch activated by the clutch lever doesn't work, I would be checking that first.........
Offline Djairouks
« Reply #7 on: March 13, 2021, 06:27:48 AM »
*Originally Posted by Thripster [+]
Right I thought about it, I changed my clutch lever back to the OEM, to be certain, but Thursday I could engage the CC for a while going to work, above 80kmh it worked but then Friday it would not set at all again.
So it's difficult to know, but to me a switch is either functioning or not, that's why I'm going back this afternoon to the dealer to leave them find the issue, I won't have time with my new job.
