Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: What to check on a used Tiger?  (Read 408 times)
Offline Blue_Rubber
  • Bike: BMW K75
« on: March 02, 2021, 01:03:16 PM »
Hi all, new member here.  :001:
Looking to buy a 2018+ Tiger, is there anything in particular I should check on the bike?
E.g. are any parts particularly prone to corrosion / failure?
Are the factory fitted heated grips any better than aftermarket ones?
Can you retrofit a lowered heated seat?
I will be using the bike to commute from Reading to Hammersmith so want it to handle motorway cruising and lots of filtering*.
* 50 miles each way which will take about 50mins > 1hr 30mins depending on traffic
Offline Tigermainia
  • Bike: Trident 660
Re: What to check on a used Tiger?
« Reply #1 on: March 02, 2021, 07:36:17 PM »
Not a lot to worry about really, the heated grips on my '18 XRt are okay but not brilliant if the bike your looking at doesn't have them then probably better to get aftermarket ones. :152:
From '61>present - '57 BSA C12, RE C/Sports, '59 Tiger 110, '61 T120R, '57 BMW R50, '76 GT185, '69 T120, KE 175, BMW R75, GSX750, FJ1200, XJR1300, FZ1000, '05 Sprint1050 & '08 Str Triple, Sprint1050, Sp/triple, Sprint1050, SprintGT, Trophy 1215, Speedtriple & '12 Bonne, '15 XRx,'18 XRt, Trident 660
