Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Multimeter Recommendations  (Read 836 times)
Offline Fazer
  • Bike: Tiger 800XRt
Re: Multimeter Recommendations
« Reply #10 on: March 05, 2021, 02:48:13 PM »
The big difference between cheap and expensive multimeters is associated with meter input impedance. This property defines how much the meter will alter the behaviour of the circuit which is being tested. Ideally youd want a meter that doesnt affect the behaviour of the circuit at all, but thats not possible.
On voltage measurements you want the impedance to be as high as possible so that the current through the meter is very small and therefore doesnt significantly increase the current through any circuit components in series with meter.
On current measurements you want the meter impedance to be as small as possible so that the meter doesnt restrict the current through the circuit being tested. Cheaper meters may also have very restricted current ranges.
If you are checking similarly priced meters then, if possible, choose one which has the highest impedance on voltage measurement, lowest impedance on current measurement and widest current range.
Having said all that, if youre only using the meter for simple voltage, current and resistance measurements on motorcycle electrics then it probably doesnt matter too much. However, once you get more confident in using your meter you may start to use it more widely and these specifications will then assume more importance.
« Last Edit: March 05, 2021, 03:16:25 PM by Fazer »
« Reply #11 on: March 05, 2021, 04:55:01 PM »
On some economy multimeters the LCD isn't backlit -- if given a choice, choose a backlighted display.
Offline GlasgowTiger
  • Bike: Tiger XRX '15
« Reply #12 on: March 08, 2021, 10:45:12 AM »
Thank you all for your suggestions, you have helped me so much! I've ordered a Draper multimeter which has the majority of the functions recommended by everyone on this post -
https://www.machinemart.co.uk/p/draper-41820-digital-multimeter/
Fingers crossed I can eventually get my head round the electrical side of things!  :001:
« Reply #13 on: March 08, 2021, 01:25:03 PM »
*Originally Posted by Fazer [+]
Since the coming of DVMs, is that still true? In the old days of analogue meters, you'd get the cheap ones which were 10kohm/V or worse and the expensive ones which might be 50kohm/V, digital meters are in the megohms/V range.
Offline pme
  • Bike: xrx lrh 2018
« Reply #14 on: March 08, 2021, 04:51:05 PM »
A point to note is that with 12volt dc electrics the currents are in 100's of mA. High impedance dvm's will give you a "good" 12 volt reading, BUT because the current draw in the meter is soooo low it will not always identify a poor connection. So you may measure 12volts with no load but as soon as the circuit is loaded it may fall.
