Hi there,
Having a similar problem after battery replacement. Found out the error code is 1552 n related to open/short relay of cooling fan. Did a complete cycle of fan kicking in and go off, but the error is still there. Will do it three times as mentioned above, hope it will sort out the warning. Is there any way to reset it manually, eg:- i had an error with cruise control and found out it happens after the replacement of heated grips and the sequence to clear it was given in the forum😊😊.
Thanks in advance
