Blue and black ones are omron G8xxxx
they have a 100 ohm resistor across the coil internally so the ecu can see they are there. The larger connectors are the coil, the two or three smaller ones are the contact
The blue one is a changover single pole, the black is a one way normally open single pole
If you are stuck for one or the other pm me, i have some spares.
