Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Scottoil Traveller  (Read 2265 times)
Offline Guyver
Re: Scottoil Traveller
« Reply #20 on: March 27, 2021, 12:55:09 PM »
 Update
This thing is dangerous. I've emailed scottoiler and it's going back for a refund. As this is gravity feeding the reservoir as at times, the reservoir gets over full. Which in turn pushes the oil out of the filling hole and around the adjustment dial.
My garage floor looks like an oil tanker has crashed and my back tyre is slippery as hell  :232:
I'm waiting to hear back from Scottoil so I can get this thing sent back for a refund.
Luckily I'm the sort of bloke who does a walk round check before taking the bike out. Otherwise the oil on the back tyre could have caused a bad accident and killed me.  :005:
Online tcbandituk
  • Bike: XRt & Street RS
« Reply #21 on: March 27, 2021, 01:26:17 PM »
Looks like the rubber strap squeezing it might be the culprit, pressure feeding it rather than gravity feed.
2020 Street Triple RS
2018 Tiger 800 XRt
2017 ZX-10R KRT Track bike
TC Drag Bike
Offline Guyver
« Reply #22 on: March 27, 2021, 04:07:26 PM »
*Originally Posted by tcbandituk [+]
I took the strap off straight after I took the photo. So not the culprit which is a shame.
Online tcbandituk
« Reply #23 on: March 27, 2021, 04:38:55 PM »
OK, so no that then.
I've got a lube tube on my Tiger which is sort of the predecessor to the Traveller I guess.
Had an overflow on that once, but it was down to me squashing it by mistake.
Been fine since.
2018 Tiger 800 XRt
TC Drag Bike
Online Paulhere
« Reply #24 on: March 27, 2021, 05:01:15 PM »
With the Magnum HCR oil gets sucked up/syphoned through. That design has worked fine for me.
Online Paulhere
« Reply #25 on: March 27, 2021, 05:11:31 PM »
Been fine since.
I'm interested in this, but wary of the bag idea. How are your oiler & lube tube located to each other? I'm wondering if yours works by gravity or syphon.
Offline Guyver
« Reply #26 on: March 27, 2021, 05:51:42 PM »
The oil on the garage floor was from the bike just sitting overnight. Again, no strap holding it down. Just placed under the rear seat. It's possible I put it together wrong, but the instructions are the worst ever. I seem to recall when fitting a scottoiler to other bikes that the reservoir shouldn't be filled to the top as it can cause leaks. Which makes sense as this fills it to the brim by itself.
Offline Guyver
« Reply #27 on: March 27, 2021, 05:54:07 PM »
If I could have one fitted to the tiger I would have done. Worked fine on my last bike. The instructions show that the bag can be placed either above or below the reservoir, so it's suction that works on the bag I'm assuming.
Online Paulhere
« Reply #28 on: March 27, 2021, 06:24:15 PM »
Keep us informed on feedback from Scottoil company.
Online tcbandituk
« Reply #29 on: March 27, 2021, 06:40:45 PM »
They're mounted side by side under the seat.
Thought I had a pic somewhere but can't find it, I can take one if you want ?
2018 Tiger 800 XRt
TC Drag Bike
