Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Standard screen fittings wanted for 2014 roadie  (Read 543 times)
Offline FredCraner
  • Bike: Tiger 800 roadie
« on: March 21, 2021, 06:39:51 PM »
I've decided to replace the scratched touring screen on my 2014 Tiger with the unused standard screen that came with it.  The trouble is, however, that I don't seem to have the 2 M5x16 bolts, flanged sleeves and locknuts that are required to fit it.  I'm really hoping that someone has some languishing in a drawer that they are prepared to let go of at less than the exorbitant Triumph prices!   :440: Cheers in advance.
Offline dtrego
  • Bike: 2014 Tiger 800
Re: Standard screen fittings wanted for 2014 roadie
« Reply #1 on: March 23, 2021, 09:19:33 PM »
If your touring screen is the larger, adjustable Triumph one - and the parts you need are the front mounting fixings... those parts were likely reused from the original screen. I just swapped from the original to the adjustable high screen on my bike, and the instructions called for reusing the bolts, bushing, and nuts for the two front attachment points. Here's a snip from the installation doc on triumphinstructions.com - part A9708272 for my US version of the screen.
Offline bitmanglr
  • Bike: 2016 800 XRt
« Reply #2 on: March 24, 2021, 01:57:57 AM »
I *just* ordered all the parts for the standard fittings so that my Givi Airflow is properly braced (Triumph part #s) since my Tiger came with the adjustible screen:
Order Contents:
P/N   Quantity   Price Each   Description
T2307980   1   $ 7.38   Screen Mount Bracket, LH
T3350010   2   $ 1.72   Locknut, Flgd, M5
T3010706   2   $ 4.26   Flanged Sleeve, 5.2 x 7 x 6.3
T3020003   2   $ 1.43   Grommet
T3330941   2   $ 5.27   Screw, But/Hd, Skt, M5 x 16, Slv
T2307870   1   $ 7.38   Screen Mount Bracket, RH
--BitManglr
Offline toonpete
  • Bike: White 800 roadie
« Reply #3 on: March 29, 2021, 04:57:21 PM »
I changed my screen and should have the original bolts unless i needed them for the madstad i fitted - if you have a pic or diagram I'll check my old bits box
live rock music and biking - it doesn't get much better
Offline FredCraner
« Reply #4 on: March 31, 2021, 09:07:13 PM »
I'm sorted now thanks folks.  Like dtrego said, it was only the side fixings that I needed as the front ones were the same.  I bought the nuts and bolts cheap from ebay, but had to reluctantly order the flanges from Triumph as I couldn't find anything similar.
Offline toonpete
« Reply #5 on: April 01, 2021, 12:04:43 AM »
Pleased you got there  :001:
Offline bitmanglr
« Reply #6 on: April 01, 2021, 01:35:23 AM »
Good to hear, still waiting on my Triumph bits I ordered on 3/18 to get here...
