Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: ABS  (Read 323 times)
Offline Seanocaoimh
ABS
« on: March 26, 2021, 03:55:20 PM »
 :260:Hi all just measured the ABS sensor gap both back and front. Front measured 0.2 , without any shim, back measured 0.23. with a 0.08 shim .Spec is 0.1/0.15.Is there a service limit for the sensor  and the abs disc ?
Re: ABS
« Reply #1 on: March 26, 2021, 04:39:36 PM »
Well the sensor face doesn't face any wear, only the brake disc, so logically the only change would be an increase in the gap you measured as the brake disc wears and provided this ABS sensor gap didn't exceed the 1.5mm (not 0.15mm) the only thing which would set any sort of service limit would be the minimum brake disc thickness limit.
Offline Seanocaoimh
Re: ABS
« Reply #2 on: March 26, 2021, 06:59:32 PM »
Stevie P , that 1.5mm makes everything ok,
