Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
April 13, 2021, 05:37:45 PM
Home
Forum
Search
Members Map
Photos Gallery
Login
Register
Triumph Tiger 800 Forum
Accessories, Products, and Clothing
Riding Gear, Helmets, Clothing, Apparel
Schuberth C3 fix
Print
Pages: [
1
Go Down
Author
Topic: Schuberth C3 fix (Read 370 times)
dasf
Tiger Member
Bike: 800 XCA 2017
Schuberth C3 fix
on:
April 05, 2021, 08:09:16 PM »
Have used Schuberth C3 and Pro helmets for many years now and like them a lot. Comfortable, low noise and no turbulence (Puig screen on my XCA 800 -17). However, I have been annoyed by two details I believe are incorrectly constructed. The first fault is that if you have the visor open, it will slam down when you increase the speed. The second fault there is no way to have the visor open about 1 cm for ventilation. I made two DIY to fix these two faults about a year ago. It took me 10 minutes and has worked perfectly.
The visor will slam down at higher speed due to lacking friction between the helmet and the visor lock on the helmet side. I mounted two rubber pieces (1 mm thick and in the form of half a washer) with double-sided adhesive tape behind each lock and the friction is enough to hold the visor in place. First I made the rubber pieces in the form of a large full washer but it gave too much friction.
The fix to the visor getting a ventilation opening of approx. 1 cm was to mount a bent cable tie (4.8 mm wide) on top of the existing locking tongue. I bent the cable tie 90 degree with a heat gun and wrapped the front part with tape to get the right height. Then put the back of the cable tie down behind the plastic ventilation part. Then put a tiny cable tie around the front of the bent cable tie and the existing locking tongue. Cut the front cable tie where it touches the lock knob in the lower part of the visor. The visor now stop against the cable tie and then locks fully when you press the visor once more.
Last Edit: April 05, 2021, 08:11:09 PM by dasf
Logged
Johnjo
Tiger Pro
Bike: 800 xrt
Re: Schuberth C3 fix
Reply #1 on:
April 06, 2021, 12:59:07 PM »
You must be unlucky mate.
I've had 2 C3's and currently using a C3 pro. Never had your problems with any of mine.
Great fix, btw.
Logged
Q
Tiger Pro
Bike: 800 XCA
Reply #2 on:
April 07, 2021, 06:26:19 AM »
have the same problem on my E1 (just a C3 with a plastic peak)
have had it back to the agent - couldn't find any fault - so, gonna apply your fix tks
Logged
OHRider
Tiger Pro
Bike: 2016 XRx
Reply #3 on:
April 07, 2021, 09:20:49 AM »
I have the same problem. Was told by a Schubert that the flip down was a safety feature. They told me to Google about a o-ring fix.
Logged
Al
dasf
Tiger Member
Bike: 800 XCA 2017
Reply #4 on:
April 07, 2021, 10:07:12 AM »
The problem with the O-ring solution is that you may get a small gap between the visor and the side sealing. Pressure (friktion via rubber) just behind the side lock prevent this.
Logged
Print
Pages: [
1
Go Up
Schuberth C3 fix
Might be a silly thought - Security
Ripsi
Today
at 04:53:51 PM
Vibrating chain guard on acceleration
awjdthumper
Today
at 04:30:38 PM
Hello from India
New Members
tauzero
Today
at 03:32:49 PM
900 GT Pro Suspension Prelaod
Ian P
Today
at 12:26:09 PM
Planning Cape York (Aust) mid 2022. How to prepare and what 'could I break'
Off-Road and Trail Talk
K1W1
Today
at 08:09:16 AM
Removing the Ugly Black Box EVAP
Kris
Today
at 04:18:22 AM
Fitting factory TPMS sensors
Tyres and Wheels
Skeet
Today
at 12:42:38 AM
Alternative Regulator Rectifiers for 800XC
Debesys
Yesterday
at 09:00:22 PM
Nav and Mount for 2018+ TFT screen tiger
For Sale
Anderson
Yesterday
at 08:58:27 PM
Heidenau K60 Scouts
For Sale
T800XC
Yesterday
at 08:17:39 PM
