Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Tiger 800 XRX Dash Not Straight  (Read 352 times)
Offline mcman56
  • Bike: 2018 XRx Low
« on: April 06, 2021, 07:02:39 PM »
A new to me 2018 Tiger 800 XRX dash or maybe it is called a screen is not quite straight to the bike.  I looks like it tilts to the left a few degrees...maybe 5 degrees even, just enough to be noticeable.  There are no functional problems, it just looks a little odd and I tend to notice things like that.  There are no signs that it has had a good fall.  Is this common?  Can you straighten the welded on mount?
Re: Tiger 800 XRX Dash Not Straight
« Reply #1 on: April 07, 2021, 06:19:43 AM »
Have you tried just loosening the mounting screws and seeing if there is any slight adjustment when you tighten then back up?
Offline Q
  • Bike: 800 XCA
« Reply #2 on: April 07, 2021, 06:21:28 AM »
already discussed elsewhere in this forum
other owners have also reported on this and the solution seems to be fitting a spacer(s)/washer(s) on the dash mountings to correct
Offline Tiggerton
  • Bike: XRT 2018
« Reply #3 on: April 07, 2021, 11:19:03 PM »
I spent some time measuring up to try and locate this anomaly (on both Tigers I have owned) then
I took my specs off and lo and behold, the dash appeared straight.
Regards.
