Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
April 14, 2021, 06:30:13 PM
Home
Forum
Search
Members Map
Photos Gallery
Login
Register
Triumph Tiger 800 Forum
Intermittent starting problem
Print
Pages: [
1
Go Down
Author
Topic: Intermittent starting problem (Read 573 times)
itchy
Tiger Cub
on:
April 06, 2021, 07:44:12 PM »
2017 800 xcx
26500 miles.
I’ve had this bike from new and serviced as per manual. Recently I’m having issues starting. Press the start button , nothing happens. Repressing, nothing. Key switch off then on, side stand down and then up again, clutch out in etc all sorts of combinations and again nothing. Several retries and the “suddenly” it starts. And of course every time since especially at the garage !
I Would guess 8 times out of 10 it’s ok.
Was out on a run Sat, 50 miles from home same again , press start button and nothing. Stopped at a view point , parked up 30mins. get back on bike and nothing.
Key out, key in , kick side stand, all sorts of combination, checked kill switch , in geR out of gear etc etc. nothing.. then out of the blue starts no problem. This has happened numerous times in recent weeks. Doesn’t seem to be any pattern
Any ideas ?
Last Edit: April 06, 2021, 07:49:14 PM by itchy
Logged
BundyJD
Tiger Member
Bike: Tiger 800 XC
Re: Intermittent starting problem
Reply #1 on:
April 07, 2021, 02:01:50 AM »
Not familiar with the dash on the XCX, but is there a warning light for the immobiliser? If so is it going out when the ignition is switched on?
Logged
chico
Tiger Jedi
Bike: 2017 XRX
Reply #2 on:
April 07, 2021, 05:45:15 AM »
I had a similar issue. Turned out one of the battery leads was loose. Have yo checked all the obvious connections?
Logged
kokkios
Tiger Master
Bike: 2016 Tiger800XRT
Reply #3 on:
April 07, 2021, 09:49:55 AM »
Sometimes mine does this but every now and then. Another reason maybe corrosion on the inside of the start button. What i found out that works is when you have the start button pushed and you dont get a response just push the button while having it pressed in towards down
Logged
itchy
Tiger Cub
Reply #4 on:
April 07, 2021, 11:00:35 AM »
Thanks for replies.
I have trawlled the forum for posting and found a few similar.
When it happens , all display indications as per normal, Battery connections good.
I was able to connect to system using Tigertool and using an interface lead bought from amazon. There are no error codes in system.
I was beginning to wonder could it be the start button not making contact as indicated previous post
Last Edit: April 07, 2021, 11:02:37 AM by itchy
Logged
BundyJD
Tiger Member
Bike: Tiger 800 XC
Reply #5 on:
April 07, 2021, 11:03:09 PM »
Make sure you check the TPMS tab in TigerTool for any codes from the immobiliser, more info in this thread -
https://www.tiger800.co.uk/index.php?topic=29217.0
Logged
chuckxc
Premier Member
Tiger Master
Bike: 12XC, 18XCX
Reply #6 on:
April 08, 2021, 07:03:10 AM »
Re-connect your battery terminal connections. Even though they might show 12V, the connection could be poor so you won't get the high current you need for the starter.
Go over all the connections in the high current circuit, especially fuse block, starter relay and fuse blades.
Also use contact cleaner on starter switch contacts and kill switch.
Last Edit: April 08, 2021, 07:04:46 AM by chuckxc
Logged
tauzero
Tiger Master
Bike: Tiger 800 XRx
Reply #7 on:
April 08, 2021, 12:53:10 PM »
I used to have this problem with a Daytona 900 and on that it as due to the clutch switch. Not sure if the Tiger's clutch switch is an improvement but it's worth cleaning if you're going over the relevant electrical bits.
Logged
itchy
Tiger Cub
Reply #8 on:
April 10, 2021, 08:09:52 PM »
Went out on a run today to check bike out. Did about 150 miles. Stopped numerous times, took key out, left bike on side stand, for various times, before restarting . No problems . Started every time!
Stopped bike using different methods, sometimes with key ( my usual method), sometimes with kill switch, sometimes left it in gear and kicked side stand out , to see if there was a pattern . Didn’t matter started every time.
The only thing that has changed , is when I plugged in and used Tigertool, I reset the service interval so that the spanner cleared from the display. ....
(Bike was serviced Dec, but the mechanic didn’t have the software to clear service indicator.. Different guy than I usually use due to dealer work load)
Coincidence.. ?
Last Edit: April 10, 2021, 08:13:55 PM by itchy
Logged
Print
Pages: [
1
Go Up
Windscreens and hearing damage
Stevie.P
Today
at 05:40:45 PM
Brake and clutch lever for 800 XRX 2019
Stevie.P
Today
at 05:33:50 PM
Newbie
New Members
Roger S
Today
at 04:55:44 PM
Might be a silly thought - Security
Ripsi
Today
at 04:38:53 PM
Just a thought!
Shergar
Today
at 03:08:34 PM
Vibrating chain guard on acceleration
awjdthumper
Today
at 08:53:21 AM
Planning Cape York (Aust) mid 2022. How to prepare and what 'could I break'
Off-Road and Trail Talk
chuckxc
Today
at 06:27:10 AM
Cheap riders seat 2013 Roadie
Items "Wanted"
Norfolk Boy
Today
at 06:16:57 AM
I gave my Tiger a new look
UncleGary
Yesterday
at 11:02:18 PM
Greetings from Poland, riding my new-to-me 800XC
New Members
bitmanglr
Yesterday
at 10:38:34 PM
