Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: V Scottoiler  (Read 710 times)
Offline Rogerthecat
V Scottoiler
« on: April 15, 2021, 10:53:40 AM »
Hi all, advice please. I've just had new chain and sprockets fitted by my Triumph dealer and mentioned I'm going to fit a v scottoiler and he said it can affect the engine running if I tap into the vacuum tube. Anyone experienced problems?
Offline crispey
  • Bike: tiger 800 thrux
Re: V Scottoiler
« Reply #1 on: April 15, 2021, 11:43:13 AM »
Cant say I've experienced any obvious problems, apart from the reservoir dumping all the oil out when the first warm day arrived and I forgot to adjust the flow
Offline Rogerthecat
Re: V Scottoiler
« Reply #2 on: April 15, 2021, 12:56:50 PM »
A point worth bearing in mind looking at the weather today. Thank you👍
Offline pme
  • Bike: xrx lrh 2018
Re: V Scottoiler
« Reply #3 on: April 15, 2021, 05:05:01 PM »
The vacuum is not "used" for more than a second or so, it simply activates the valve on the oiler so providing there are no leaks in your pipework it is not an issue.
Offline Tallpaul
  • Bike: 800XR
Re: V Scottoiler
« Reply #4 on: April 15, 2021, 06:45:24 PM »
I have a V Scottoiler on my gen 2 800, no problems at all with running.
Offline Rogerthecat
Re: V Scottoiler
« Reply #5 on: April 15, 2021, 06:57:04 PM »
Thanks for the advice - puts my mind at rest👍 Can have a go at fitting now 😊
Offline Tallpaul
  • Bike: 800XR
Re: V Scottoiler
« Reply #6 on: April 15, 2021, 09:41:04 PM »
Which generation Tiger do you intend to fit it to? There are different tubes to cut, depending on year.
Online AndrewNZ
  • Bike: 900 GT Pro
Re: V Scottoiler
« Reply #7 on: April 16, 2021, 08:54:30 AM »
I fitted the X-system to my 900 and not only is it doodle to fit it works really well.
You are only jealous as the voices are seeking to me!
Offline Rogerthecat
Re: V Scottoiler
« Reply #8 on: April 16, 2021, 09:05:45 AM »
My Tiger is a2016 xrx low. I know the scottoiler is connected via the vacuum pipe on the LHS that runs from the injectors to just behind the gearbox. My reason for posting this question was whether or not it causes the nothing to run differently. The general consensus seems to be it's not a problem. Thanks all👍
Offline dragon88
Re: V Scottoiler
« Reply #9 on: April 19, 2021, 04:54:44 AM »
Personally I prefer the Cobbra Nemo 2. Far simpler and more reliable.
