Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Clutch replacement suggestions  (Read 366 times)
Offline TheMaddSquirrel
  • TheMaddSquirrel
  • Bike: 2013 Tiger 800
« on: May 04, 2021, 02:04:06 AM »
I've got 10k miles, I'm not sure how long this clutch has left, as I just bought used. Looking for replacement suggestions and part numbers so I can not waste time returning the wrong parts. (I defer to your mastery)
 Thanks in advance
Squirrel
Offline awjdthumper
Re: Clutch replacement suggestions
« Reply #1 on: May 04, 2021, 05:44:54 AM »
That sounds like an awfully low mileage to be thinking of replacing the clutch - unless it is displaying an obvious problem, I would not worry about it?
  • TheMaddSquirrel
« Reply #2 on: May 04, 2021, 05:50:50 AM »
I agree, though I still would like the proper part numbers if you know of a thread I can check?
Squirrel
Offline awjdthumper
« Reply #3 on: May 04, 2021, 06:10:38 AM »
I assume you are thinking in terms of just replacing the friction plates rather than anything more fundamental? Here in the UK, it would just be a case of looking up the parts diagram and list from someone like Fowlers and then ordering what you need:
https://www.fowlersparts.co.uk/parts/5597369/tiger-800-xc-to-vin-674841/clutch
  • TheMaddSquirrel
« Reply #4 on: May 04, 2021, 06:20:24 AM »
Excellent, thank you.
Looking at, specifically gasket for outer case, and going most likely with Barnett clutch 303-75-0675, gasket I'm coming up with  T1260141, for the 2013 Tiger 800 xc
Squirrel
Offline awjdthumper
« Reply #5 on: May 04, 2021, 06:27:19 AM »
That looks to be the right number but, surprisingly, Fowlers shows it not to be in stock??
  • TheMaddSquirrel
« Reply #6 on: May 04, 2021, 06:30:25 AM »
Thank you. Same issues here in US, most on backorder
Squirrel
Online chico
« Reply #7 on: May 04, 2021, 04:19:15 PM »
Hey Squirrel, I've had a bad outcome with Barnett clutch components on one of my Hondas. Why not get the OEM parts? They work well. If you do decide to replace the clutch plates you might consider getting new springs as well. They're cheap and since you're there already you might as well.
Offline freeware
« Reply #8 on: May 04, 2021, 06:52:17 PM »
I've inspected my clutch at 32k and all was as new/nominal. Put it back together and expecting another 30k to munch.
While you'll be working in this area I would suggest to check your return spring and consider preventative maintance/mod of the gear selector pin. This was actually main reason I went there. Your 2012 bike is a high risk - multiple reports of the failure.
Offline Derchef1962
  • Bike: 800 Roadie, 2013
« Reply #9 on: May 04, 2021, 08:38:03 PM »
85,000 kms on my Tiger clutch still fine, so why worry with only 10,000 miles?
