Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Fork oil for 2016 xrx.. what are you guys using  (Read 266 times)
Offline Miles Prower
  • Bike: Tiger 900 xrx
« on: May 12, 2021, 01:06:41 AM »
As the title says what grade are you all using on the 2016 xrx or equivalent,  and the rationale?
Haynes manual says SAE10
Offline sprucetiger
  • Bike: 2021 Tiger900GTP
Re: Fork oil for 2016 xrx.. what are you guys using
« Reply #1 on: May 12, 2021, 01:48:24 AM »
If you want more cushion, go to a higher weight.  I went to a 15w in my old 2014 800 XC.  It helped, but wasn't enough.
I ended up going with fork cartridges to really get the compression I wanted.  Oil will help with minor adjustments, but go for new springs if you are heavier than the "standard" rider (whatever that means).
