Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Buffeting  (Read 2241 times)
Offline Suasages
Buffeting
« on: May 28, 2021, 02:32:57 PM »
Hi sausages here From Cornwall
Offline Suasages
Re: Buffeting
« Reply #1 on: May 28, 2021, 02:37:33 PM »
Hi again just joined as I e had a problem with my tiger since Ive. Bought it tried various screens and even cut down a touring screen gradually to try to cure the horrendous buffeting.
Offline Suasages
Re: Buffeting
« Reply #2 on: May 28, 2021, 02:46:01 PM »
Hi again please forgive the way Im doing this but I would like to share my cure for wind buffeting and this is the first time Ive ever been on a chat room and I dont h e a clue how to use it   . But I have worked out a cure for buffeting whilst considering whether or not to change back to sports bike .
I just need to work out how to add a picture now
Offline Roger S
  • Bike: 800 XRT
Re: Buffeting
« Reply #3 on: May 28, 2021, 08:09:41 PM »
Keep trying Sausages, we need to know !
When you post a message there is an icon that reads Upload Images, that should be the kiddie.
Offline Suasages
Re: Buffeting
« Reply #4 on: May 28, 2021, 09:47:39 PM »
Sorry cant do this but I think the pics are in the album marked by sausages
Airflow goes under and over screen and creates the buffeting as it goes at different speeds the gets to top of screen and causes turbulence ( buffeting) one pic is duct tape and one pic is soft pipe insulation (just close the gap between screen and headlamp casing. Trying to make a more visually pleasing solution . Dont Laugh because it Works
Offline Suasages
Re: Buffeting
« Reply #5 on: May 28, 2021, 11:32:19 PM »
Ha ha Done it
Sausages (suasages) Spelt it wrong
Offline dragon88
Re: Buffeting
« Reply #6 on: May 29, 2021, 02:00:57 AM »
You are better off spacing out the bottom mounts of the screen by 20mm (cut reinforced fuel/oil line works well) with longer 5mm screws. Achieves the same outcome minus the ugly.
Re: Buffeting
« Reply #7 on: May 29, 2021, 06:35:23 AM »
I'd assumed the buffeting was only associated with the air flow over the top of the screen but will close off the bottom of the screen to see what difference this makes. It would be nice not to have the buffeting!
Re: Buffeting
« Reply #8 on: May 29, 2021, 08:05:21 AM »
*Originally Posted by Suasages [+]
Ha ha Done it
That will make things worse. You need the airflow up under the screen so there is no negative pressure behind the screen which is one if the causes of buffeting.
Buffeting is very individual and is often more to do with the rider and their expectations than the actual bike.
Things to try
Take the screen off completely
Fiit a wind deflector on top of the screen
Take the mirrors off or fit spaces to move them wider
Try a new helmet
See if you can adjust your riding position
Offline Suasages
Re: Buffeting
« Reply #9 on: May 29, 2021, 08:31:58 AM »
Hi Done all that inc spent 600 on a C4 pro .
Just try the tape
