Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: TC & ABS warning lights on my 900 GT  (Read 350 times)
Offline YorkieBoy
  • Bike: Tiger 900 GT
« on: June 01, 2021, 09:43:54 AM »
Returned last night from a great 350 mile back road ride around to my brother's in Pickering on my fairly new (4500 miles) 900 GT. 20 miles from home I seized a passing opportunity and gave it the biggest beans it had had all day. I was presented with a technicolour display telling me the Traction Control and ABS had failed. I tried locking the back wheel but that rear brake...no ABS rattles anyway. I stopped, switched off & on and it appeared to clear the system. The warning lights have not returned (yet) but I guess a visit to the dealers is in order.
Anyone else experienced this? Apologies if I've missed the answer.
Half the world have a less than average intelligence
C15, 350 Mac Velo, 200 Lambretta, 175 Jawa, 500 AJS Model 20, 650 SS Norton, 750 Commando, SP370 Suzuki, Guzzi Le Man II, Tiger 955i, Speed Triple, 1600 Tbird, Street Triple, 1700 Tbird, Explorer, 1700 LT, Street Triple, Tiger 800 XRT, 900GT
Re: TC & ABS warning lights on my 900 GT
« Reply #1 on: June 01, 2021, 12:01:37 PM »
1. Check for fault codes with diagnostic software, I.e Tigertool or I think there is a routine for displaying the fault codes, possibly in 900 handbook, definitely can on the 800 though not in the handbook, or search recent forum threads.
2. Check battery charging voltage, but really needs to be checked if fault lights reappear and, on the 800, that's a pain if the bike needs switching off the remove seat for access. The reason I mention this is I had months of occasiinal similar fault lights before they finally came on permanent and I had around 19v charging at idle and it was the regulator/rectifier finally giving up.
https://www.tiger800.co.uk/index.php/topic,24031.0.html
« Reply #2 on: June 01, 2021, 01:18:10 PM »
That's exactly what will happen if it is still in Off Road or Off Road Pro Mode.
Turning off and on again the ignition will automatically revert to Road Mode, and no warnings.
Offline YorkieBoy
« Reply #3 on: June 01, 2021, 02:19:39 PM »
Both responses are much appreciated. The bike's only a year old and has been regularly used so I don't think it's the battery or rectifier - but I will check this. It wasn't in Off-Road Mode but the symptoms do bear this out. In my excitement of releasing the horses, how unlikely is it that I accidentally knocked it into Off-Road?
Offline TIger Lad
  • Bike: Tiger 900 GT PRO
« Reply #4 on: June 01, 2021, 03:38:19 PM »
Nothing like that happened to my gt pro, only hiccup I have had was today when I had to brake very hard, closed throttle, clutch in and the engine suddenly stopped no warning just stopped.  Out again tomorrow try repeat what you did see what happens.
« Reply #5 on: June 02, 2021, 06:11:11 AM »
The bike must be stopped to switch into Off Road Mode .
So if you did accidently switch to that mode, it would have happened while stopped, not while accelerating.
It is possible to do by mistake while stopped because you don't have to do the usual throttle close step.
If everything has been good since, then I'd say that could be a possibility.
Offline YorkieBoy
« Reply #6 on: June 06, 2021, 04:01:02 PM »
I've taken the bike out a couple of times to try replicating the fault, but to no avail. Tried an emergency stop from 95mph (always good practice) and the rear ABS kicked in as the tyre unloaded. All seem fine, which is a good thing as the local Triumph dealer tells me he cannot check the faultcode until late August! This could be a spite thing as I gave him a bollocking for poor service 6 years ago. There are dealers within 50 miles other than Webbs of Peterborough :002:
