Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Knocking (ringing, clinking) of the Tiger 800XC 2014 engine (mileage 12,000 km)  (Read 1508 times)
*Originally Posted by mcman56 [+]
I see the link but am not sure what you did to correct.  Did you add a fastener to the front of the cover?  Item 41 looks like a grommet to me.
No, there is no fastener at the front, it is only held by the cable, & I'm guessing, the 2 sticky pads secure it to the expansion tank. All looks like an afterthought to stop clutch cable from rubbing on Rad.
Only a 15 min job to remove the plastics, remove the finisher panel, fit it to the cable & replace.
Sticky pads ordered off ebay. I'll just fit one at front in case it's a pita to get off for change cable at any time.
Offline mcman56
  • Bike: 2018 XRx Low
Interesting, the cover on mine also feels a bit loose so that could be it.  The cover has a couple of grooves/ clips in the front that look like a clutch cable guide but the clutch cable is attached to the frame with bracket and screw.  See pics.  Nothing appears to be holding the front of the cover.
Is the cover loose at front or held by sticky pads to the expansion tank? Not doing anything if your cable is secured to the frame. That must be mk2 bodge.
Offline mcman56
It is not tight. It looks like I could secure it with tie wrap to what looks like the clutch cable track
I've now fitted a piece of sticky pad to the front of the cover. That flimsy clip off the bkt is holding my overflow pipe.
Offline san
  • Bike: Tiger 800 XC 14
I solved the problem with the knocking in the engine! The problem was the engine oil. The engine was filled with a Castrol Power Racing 10W40. I poured a thicker Motul 7100 10W50! All the knocks are gone, the engine is running quietly! I drove only 1000 km on Castrol, apparently it is too liquid for our engine, although it is recommended by the Triumph factory
Offline Derchef1962
  • Bike: 800 Roadie, 2013
*Originally Posted by san [+]
that is strange I am using this Castrol oil for 86,000 kms now and never had a knocking sound from the engine
...knocking in the engine! The problem was the engine oil. The engine was filled with a Castrol Power Racing 10W40.
...apparently it is too liquid for our engine
Maybe apparent for "your" engine?  :187:
10W40 is the correct and  best oil for the Tigers. You may have treated a symptom, but doubt you have found the real cause of your problem.
... Castrol Power Racing 10W40.
This is what I use. Though in Halfords if you use their oil selection guide they show 10W40 of all makes of oil suitable except Castrol where they list using their 10W50. :027:
