Horn doesn't work
(1/1)
Derchef1962:
Hi there
MOT next week, horn does not work, indicators, high beam are fine. Can't be a blown fuse or can it? I used a fair amount of contact spray on the horn switch with no effect.
So it's either the switch or the horn, right?
Shergar:
Easy enough to check if you have a meter, the horn connections are just about accessible if you have nimble fingers.
One side should be live as soon as ignition is on, if neither is then its a fuse / feed issue. the other side completes the circuit when the horn button is pushed.
If you don't have a meter but have a very low wattage bulb you can try to use that in place of the horn to see if it lights when the button is pressed.
kokkios:
Had this problem myself. Turned out the horn switch connections got a bit rusty and needed some scrapping with sandpaper
Derchef1962:
Originally Posted by Shergar Easy enough to check if you have a meter, the horn connections are just about accessible if you have nimble fingers.
Left handed on both hands, that's me. Helpful info though, I 'll talk to my trusted mechanic.
