Author [NL] [FR] [ES] [DE] [SE] [IT] Topic: Tiger 800 XRX Low - Rear wheel Lift for Servicing  (Read 2376 times)
  • Offline mcman56
    • Tiger Member  ‐    51
    • #10
    Offline mcman56
    • Bike/Model: 2018 XRx Low
    Re: Tiger 800 XRX Low - Rear wheel Lift for Servicing
    Reply #10 on: Jul 12, 2021, 02.32 pm
    It will not stay mounted and is just attached with a couple of pins when used.
  • Offline Blue_Rubber   gb
    • Tiger Member  ‐    87
      #11
    Offline Blue_Rubber
    • Bike/Model: 2019 XRX Low
    Reply #11 on: Aug 02, 2021, 09.59 pm
    mcman56, I have the same lift and scissor lift as you. What I do is: put a piece of carpet on the scissor lift flat top and raise the rear of the bike by placing it under the suspension points. Works well and no jerry rigged welded contraption.
    Could you post a few photos of this please so I can try and replicate your method?
  • Offline mcman56
    • Tiger Member  ‐    51
    • #12
    Offline mcman56
    Reply #12 on: Aug 02, 2021, 11.11 pm
    See attached.  If you have a similar scissor lift, I would recommend a similar height.  As is, I can mount the frame to the bike, tilt it up and slide the lift under.  Even before lifting it is somewhat stable so in some ways easier than a center stand.  As close as I can measure, the tabs on my frame are 12" apart, center to center.  One is 3" lower and 1" forward of the other.  I find the exact inch measurements very odd. I used a couple of these clevis mounts for attachment,  Tube is 1 x 1 x 1/8"  (I'm not a good welder.)
       https://www.aa-mfg.com/product/clevis-3-8-holes-3-16-steel/
  • Offline chico   us
    • Tiger Jedi  ‐    1389
      #13
    • Bike/Model: 2017 XRX
    • Country: us
    Reply #13 on: Aug 03, 2021, 05.19 am
    *Originally Posted by Blue_Rubber [+]
    I'd like to oblige but at the moment I have another bike on my lift. I'll be able to take a picture in the next few days.
    • Tiger Member  ‐    87
      #14
    Offline Blue_Rubber
    Reply #14 on: Aug 03, 2021, 05.02 pm
    Thanks Chico!
  • Offline Dozza Dawes
    • Tiger Cub  ‐    6
      #15
    Offline Dozza Dawes
    • Bike/Model: Tiger 800 xrx
    Reply #15 on: Aug 11, 2021, 08.39 pm
    Hi all
    Simple 20 fix for the lack of center stand.  works perfectly.
    Cheers Doz
    • Tiger Member  ‐    87
      #16
    Offline Blue_Rubber
    Reply #16 on: Aug 13, 2021, 03.42 pm
    Thanks that looks very useful I am trying to decide between that and the Tirox SnapJack V2:
    https://www.amazon.co.uk/SNAPJACK-PORTABLE-MOTORCYCLE-Motorbike-Maintenance/dp/B01M667XQ7
    As in theory I could remove the rear wheel with the latter.
  • Offline chico   us
    • Tiger Jedi  ‐    1389
      #17
    • Country: us
    Reply #17 on: Aug 13, 2021, 04.20 pm
    Hi Blue, I haven't forgotten about your request. I currently am finishing some touches on my Honda CBX which I've sold and will be picked up on Sunday. This will free up my lift for the Tiger so that I can snap some pics for you.
    Sorry it took me so long but had some issues on the CBX to attend to.
    • Tiger Member  ‐    87
      #18
    Offline Blue_Rubber
    Reply #18 on: Aug 13, 2021, 06.35 pm
    No problem at all Chico  :002:
  • Offline mcman56
    • Tiger Member  ‐    51
    • #19
    Offline mcman56
    Reply #19 on: Sep 12, 2021, 12.39 am
    I thought I should warn anyone that may try to reproduce the lift frame.  I found that wiggling the bike around on the lift would allow it to slide forward.  The scissor lift is has some play so must be able to lean a little.  I had to add some stops to prevent this from happening.
