Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Got new tiger 900 and not happy  (Read 1706 times)
Offline hancop
« on: August 12, 2021, 08:55:25 PM »
Have not even ridden it yet and all screens showing the shock icon in lower right and the tes tab which is the electronic shock says system fault to the right of it
Offline flyingburrito
  • Knees in the breeze
  • Bike: 900 Rally Pro
Re: Got new tiger 900 and not happy
« Reply #1 on: August 12, 2021, 09:41:17 PM »
So you picked up the bike without starting it up.   Assume this was at a dealership.   Why did you not notice when you took possession and have the dealer diagnose/correct.
Instead you run to a message board and complain?
2020 Tiger 900 Rally Pro
Ride along with me on beautiful San Diego, California trails... @ https://www.youtube.com/channel/UCS6zojgZ5rzWpKNf1_MPf9Q/videos
Offline hancop
« Reply #2 on: August 12, 2021, 09:55:29 PM »
We did start it and dealer ran through all options and everything and no issues.
Drove it in truck 5 hrs home, put in garage then went to set it all up today and got this issue. No idea why
Online chuckxc
« Reply #3 on: August 12, 2021, 10:43:29 PM »
Would seem to me loading and unloading it on the truck is a possible cause in disrupting the suspension.
Review the method used. Take it for a drive and see if the suspension recovers and the faults clear.
Offline hancop
« Reply #4 on: August 12, 2021, 11:16:41 PM »
I plan to drive it a bit to see. No chance loading and unloading did it, was walked on and off on a level platform. Therefor no different than pushing bike around in a garage
Online chuckxc
« Reply #5 on: August 13, 2021, 01:39:01 AM »
*Originally Posted by hancop [+]
What about the usual tie down and consequent  compressing of the front forks for the 5 hr transport?
Offline hancop
« Reply #6 on: August 13, 2021, 02:25:23 AM »
That should not be an issue either as the message according to the dealership,when I called is related to the electronic rear suspension. The front is not electronic
Offline bazthebike
  • Bike: Explorer/900GT
« Reply #7 on: August 13, 2021, 10:33:43 AM »
When my explorer says suspension fault on start up i just sit on it with engine running and it recalculates the load and resets itself. It wont reset if you are moving.
Offline coach
  • Bike: 2021 Tiger 900GT
« Reply #8 on: August 13, 2021, 07:00:17 PM »
Which model T900 did you buy?  If its not the Pro version and the battery gets disconnected (even for a short time - seconds) a fault will show up on the display as the computer is looking for the Electronic Suspension, which is not there.  Has happened to me twice on my 21 T900 GT (not a Pro).   Easy to fix by going into your display and selecting Off on the Electronic Suspension.
Disconnection of the battery will also mess with the Service Due indicator.  After your first Run in Service you can fix that too in the display settings mode.  Dont ask me how I found out about all this!  :164:
« Last Edit: August 13, 2021, 07:04:13 PM by coach »
coach - 2021 Tiger 900 GT
Offline hancop
« Reply #9 on: August 13, 2021, 07:34:48 PM »
It is the pro version, and tried the on and off of the tes system and did not work. Have appt with service this coming wed so hopefully fixed then
