Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Notchy gears since oil change  (Read 1475 times)
Offline mikegml
« on: September 06, 2021, 08:41:02 PM »
Changed oil and filter on the 2011 800 last month, haven't ridden it much since then but have been out on it the last few days and I'll swear it's a bit more notchy than before.
Bit of a pig to find neutral from 2nd, keeps going through to 1st then through to 2nd from 1st, and generally just not as smooth. Also seems a bit more loose. It's fine when moving it's basically when at a standstill or coming to a stop and taking off. Can't recall what oil I put in but it was top notch stuff, expensive, fully synthetic.  Think it was Silkolene.
« Last Edit: September 06, 2021, 09:21:41 PM by mikegml »
Re: Notchy gears since oil change
« Reply #1 on: September 06, 2021, 08:52:40 PM »
I would be more inclined to suspect the chain when gear changes get notchy .... incorrect tension, tight spot, a siezed link, etc. and the oil change is coincidental.  :027:
Offline mikegml
« Reply #2 on: September 06, 2021, 08:59:47 PM »
Nope. chain spot on, nowt to do with chain. As stated, only noticable at standstill, at lights, etc. great when moving.
« Last Edit: September 06, 2021, 09:03:23 PM by mikegml »
« Reply #3 on: September 06, 2021, 10:05:05 PM »
I've had problems with my other bike after an oil change which resulted in slight clutch drag making it difficult to find neutral. Irt would be interesting to know what the new oil was?
Offline mikegml
« Reply #4 on: September 06, 2021, 10:06:56 PM »
As stated it was fully synthetic, I'm pretty certain now it was silkolene.  I don't want to exaggerate this problem, it's not 'really bad' but def' not as good as it was.
« Last Edit: September 06, 2021, 10:23:12 PM by mikegml »
Online K1W1
« Reply #5 on: September 06, 2021, 10:42:16 PM »
Oil does make a difference. I always found that Suzukis changed much smoother with Motul oil in the engine as opposed to others brands.
« Reply #6 on: September 07, 2021, 09:30:33 AM »
*Originally Posted by mikegml [+]
Likely plates dried off through lack of use.
Offline mikegml
« Reply #7 on: September 07, 2021, 10:51:27 AM »
You gotta be joking.  Plates dried off after just a few weeks not used?  The forums would be full of riders with dried off plates if that was the case. I've not used the bike for months over winter and had no problem. It started just after the oil change.
« Reply #8 on: September 07, 2021, 01:18:47 PM »
You're the expert, why you here with your problems.
Offline mikegml
« Reply #9 on: September 07, 2021, 01:55:25 PM »
I'm not being stroppy with you mate. I think it's such an unlikely explanation. How would the plates dry out?  Even if the bike was standing for months with no oil in at all it's unlikely. It was old oil out new oil in.  And a new set of clutch plates would be dry when fitted, can't get much drier than that.
