Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Tank + Fuel Pump Compatibility  (Read 441 times)
Offline HugoV
  • Bike: '15 Tiger 800XCx
« on: September 09, 2021, 09:05:09 PM »
Hello all,
I have 2015 Tiger 800 and I damaged my tank and I need to replace it (irreparable).
I'm wondering if I can mount a tank from a 2010-2014 Bike or 2017-2020 Bike on my bike and use my actual fuel pump assembly.
Thanks in advance.
Online K1W1
Re: Tank + Fuel Pump Compatibility
« Reply #1 on: September 09, 2021, 11:30:51 PM »
I believe that the physical tank is the same on all the Tiger 800 models. The little protection bar in the opening changed a bit bit that is of no consequence. The fuel pump could possibly have changed in 2015 or 2018 when tweaks and changes were made to the FI system but a search of part numbers somewhere like World of Triumph may help but I doubt that the fitting would have changed so most likely your pump will fit okay.
Offline HugoV
« Reply #2 on: September 12, 2021, 01:37:39 PM »
I checked, the fuel pump has the same part number but 2017+ models have an additional part (T3020330), it says "Grommet, Rectangular", I don't understand what purpose do they serve.
Do you have any idea ?
« Reply #3 on: September 12, 2021, 04:44:31 PM »
Are you sure that part is listed for a Tiger 800 - a quick look shows T3020330 is used on other Triumph as part of the cockpit?
Offline HugoV
« Reply #4 on: September 12, 2021, 06:20:08 PM »
You are right, the schematic I found wasn't very clear, they are used on multiple triumph models, they are the grommet that hold the side fairings on the tank.
Online SOHUTAA
  • Bike: T800 Xcx 2016
« Reply #5 on: September 12, 2021, 09:31:17 PM »
Concernant les rservoirs, je ne peux apport aucune rponse . . .
Par contre attention, les pompes essence des gnrations II ( 2015=>), sortent le carburant une pression suprieure aux gnration I (2011 2014).
