Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Recommendation for tyers  (Read 218 times)
Offline Eman
  • Bike: Tiger 800 xrx
« on: September 12, 2021, 08:19:04 AM »
My bike has just gone in for its MOT, mechanic suggesting new back tyre as its only just legal and suggesting Michelin5s quoting a possible 500 for a set of tyres and fitting.  This is my first triumph, past bikes cost half of this and feeling a little twitchy about the quote, any advice/recommendation for tyres? Tiger 800 zrx low 2015.
Offline matt748
  • Bike: 900 GT PRO
Re: Recommendation for tyers
« Reply #1 on: September 12, 2021, 08:38:13 AM »
*Originally Posted by Eman [+]
Michelin road 5s are very good tyres and work well on the 800. My rear wore quite quickly though.
The quote is high. 250-300 for a set fitted is more realistic.
Offline Eman
« Reply #2 on: September 12, 2021, 09:26:42 AM »
Thanks, when you say that your back tyre wore quickly, how many thousand miles did you get out of it?
« Reply #3 on: September 12, 2021, 12:07:53 PM »
Just had a pair of Metzeler Roadtec 01 SE's fitted on Thursday, 282 ride in/out. That's on my 1050, went for them 'cos they're brill on my T800 XRx which have now done over 4k miles & now at 3mm/4.5mm f/r eg 1/3 worn. They start at approx 4mm/6mm f/r. I doubt that means they'll do 12k miles. I'd be happy with 8k.
« Reply #4 on: September 12, 2021, 02:27:41 PM »
*Originally Posted by matt748 [+]
Although about 2yrs ago my set of Michelin R5's cost about 240 fitted to loose wheels (I use Pro-Tyre/GupaP). Ride in Ride out extra 18 per wheel .... certainly no way in excess of 300. The rear (for me) lasted approx. 8k miles. Fantastic tyres and if you're not already aware from the hundreds of posts in the actual 'wheels and tyres' section then if not already changed, whatever tyre you pick, put a 110/80R-19 radial on the front and ditch the 100/90 Bias belted OEM fitted size, transforms the handling.
https://www.tiger800.co.uk/index.php/topic,28871.10.html
