Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Strange oddity. Bike stalls when riding and won't restart  (Read 1859 times)
Re: Strange oddity. Bike stalls when riding and won't restart
« Reply #10 on: October 05, 2021, 11:03:07 PM »
Not necessarily if the switch is electrically intermittent internally. That switch disables the ignition, like when you put the sidestand down while in gear and the engine running.
 Or the connector(s) are intermittent
« Last Edit: October 05, 2021, 11:05:18 PM by chuckxc »
Offline benebob
  • Bike: 13 800 ABS
« Reply #11 on: October 05, 2021, 11:05:04 PM »
If that were the case it would have cranked and started though it didn't.  It only cranked.
Offline chico
« Reply #12 on: October 06, 2021, 01:05:45 AM »
Sounds like a fuel problem to me. :112:
Offline benebob
  • Bike: 13 800 ABS
« Reply #13 on: October 06, 2021, 01:54:46 AM »
Wouldn't there be fault codes if it were a fueling problem  and wouldn't it run lean a few revolutions?  It cuts out like you hit the kill switch.
« Reply #14 on: October 06, 2021, 06:33:31 AM »
The list of possible fault codes for the fuel system is limited to throttle position sensor problems and fuel pump relay problems and probably of no help in this case.
Unfortunately, these modern bikes are very complicated and sorting out intermittent problems is extremely difficult since it could be due to one of many possible causes including faulty sensors or faulty switches or connections. You stand a better chance of diagnosing the cause of the problem if you can get it to show itself when you are in a position to carry out basic testing such as for the presence of a spark and for the presence of fuel pressure.
« Reply #15 on: October 06, 2021, 11:42:23 AM »
*Originally Posted by benebob [+]
No. If the side stand switch is faulty, the engine won't get any ignition.
Offline benebob
  • Bike: 13 800 ABS
« Reply #16 on: October 06, 2021, 01:43:18 PM »
Please explain further.  My understanding is that if the engine cranks then the side stand switch, neutral switch and clutch switch are working as if any of those are in the wrong position or not working you won't get any cranking when you push start.
Offline benebob
  • Bike: 13 800 ABS
« Reply #17 on: October 06, 2021, 01:50:33 PM »
Really?  What is the point of having a computer then if it doesn't find such issues.  As for fuel pressure wouldn't it have fuel pressure if it primes or is the Triumph system too dumb to measure pressure at all, just turn the pump on for x seconds and assume it is primed?  Even my Himalayan has faults for fuel pressure and faulty fuel pump circuit.  Of course I've also never heard of a fuel pump failing where it works one day and not the other either unless the bearings are gone which I would think you would hear.
Would love  for it to rear its head but of course 2x over a month means I won't ride the thing as it isn't reliable.
Offline D6864
  • Bike: White XC
« Reply #18 on: October 06, 2021, 02:52:20 PM »
Check the crankshaft position sensor, these tend to fail when hot then recover after cooling down.
Offline benebob
  • Bike: 13 800 ABS
« Reply #19 on: October 06, 2021, 05:29:11 PM »
Know any way to check it for intermittent rather than throwing a new part at it?  Wouldnt it send a code if it was bad or would it just stop reading where to fire?
