Author [NL] [FR] [ES] [DE] [SE] [IT] Speedo dropout and other woes  (Read 1739 times)
  • Offline Banksy73   gb
    • Tiger Cub  ‐    7
    • #10
    Offline Banksy73
    • Bike/Model: Tiger 800 XCX
    • Country: gb
    Re: Speedo dropout and other woes
    Reply #10 on: Feb 15, 2022, 07.07 pm
    *Originally Posted by Snownorge [+]
    Hard exactly the same on mine,new reg/rec cured it.
    Sounds like I might be able to go direct for a new reg/rec rather than buying a voltage monitor and getting confirmation that the voltage is all over the place. Oh wait, I've already ordered the voltage monitor.
    As for a replacement reg/rec, I'm a little uncertain where to source this. I've read the 2018 thread in which StevieP recounts the tale of replacing his R/R in time for the Megameet, in which he wrestles (mentally, obviously) with various options (FH020AA? FH012AB? etc).
    I'd appreciate any advice of part specification and possible suppliers of a suitable R/R. My Tiger is a 2016 XRX (so no heated seat - ludicrous idea!)
    Apologies if this sounds a bit needy but I'm all at sea on stuff like this. Oh yes, and I don't want to end up paying Triumph's exorbitant margin.
  • Offline Londonglide   gb
    • Tiger Master  ‐    283
      #11
    Offline Londonglide
    • Bike/Model: XC
    • Country: gb
    Reply #11 on: Feb 15, 2022, 07.20 pm
    My thoughts
    FH012  Original from 2011
    FH020  Replacement from around 2015
    AA/AB suffix are not really indicative of anything we need to worry about.
    Either OK, but my experience was the 020 was more stable, however, I used lots of Di-electric grease on my connections, so maybe that helped.
    Fit OEM, not aftermarket, unless its a Ricksport thing. Used oem  would be my preference rather than unbranded, even from respected dealers.
    YMMV, as they say.
    If your quick
    https://www.ebay.co.uk/itm/275156410402
    Last Edit: Feb 15, 2022, 07.22 pm by Londonglide
  • Offline awjdthumper   gb
    • Tiger Master  ‐    899
      #12
    • Bike/Model: Tiger 800 XCA
    • Country: gb
    Reply #12 on: Feb 15, 2022, 07.46 pm
    I would definitely do the voltage monitor test during a ride around the block as it is a lot of trouble to replace the existing R/R and it may be unnecessary. However, if at any point during the test the voltage goes above, say 15 V, then the R/R will almost certainly need replacing. As said, it's best to replace with an Shindengen OEM R/R because they don't all work the same way and other makes may be less reliable.
    Suzuki GSX1400, Armstrong MT500 + collection of classic British bikes
  • Online Stevie.P   gb
    • Tiger Jedi  ‐    4829
      #13
    • REME -'Arte et Marte' ... By Skill and by Fighting
    • Bike/Model: 2015 Tiger XRt
    • Country: gb
    Reply #13 on: Feb 16, 2022, 01.11 pm
    *Originally Posted by Banksy73 [+]
    No, I didn't really have any wrestling with options just hassle getting what I wanted fast and preferably cheaper then Triumph price. I wanted a replacement FH020AA and eventually ordered one from my dealer but when it arrived Triumph had fobbed me off with an old model FH012AB packaged under the FH020AA part number and I suspect they were sneakily clearing old stock. :023:
    I would definitely stick with FH020AA as your replacement and I'm also in the buy a genuine (new or s/h) Shendingen one group, not a cheap pattern one.
    As for heated seats .... I only got the XRt because at the time I fancied a change from boring black/white/blue option of the other models and I really liked the orange. I had no interest in the heated gizmos .... until I tried them and now I wouldn't want to give them up (and others here have voiced the same). The seat heats the base of the spine, a major blood flow point around the body and as such is really appreciated as an all year around rider and though I've removed the hard Triumph heated seats I was fortunate enough that the super Sargent seats I bought on here had a heated front one. :028:
    • Tiger Cub  ‐    7
    • #14
    Offline Banksy73
    • Country: gb
    Reply #14 on: Feb 18, 2022, 10.51 am
    Update: I've ordered a plug-in voltage monitor and a reg/rec (FH020AA). But I'll take AJWDthumper's advice and run the voltage monitor on the bike before attempting to replace the reg/rec.
    Thanks for all your help, guys. I'll let you know whether the remedy solves the problem. :763:
    • Tiger Cub  ‐    7
    • #15
    Offline Banksy73
    • Country: gb
    Reply #15 on: Jun 11, 2022, 05.45 pm
    This is a bit late. But just to let you know that I replaced the reg/rec with a 40 second-hand one off eBay. Bingo! Problem solved.
    So thanks to everyone who helped with info etc.
  • Offline Tiggerton   gb
    • Tiger Pro  ‐    226
      #16
    Offline Tiggerton
    • GTPro
    • Bike/Model: 900 GTPro 2021
    • Country: gb
    Reply #16 on: Jun 13, 2022, 03.31 am
    I had this problem on the 800. The wiring from the rear wheel sensor had shorted to the cable clip on top of the swing arm.
    Regards
