I've owned there Tiger 800's, Gens 1-3. The Gen 3 XCA is the real deal, it lacks nothing (rather annoying gear whine from the straight cut on the imput shaft after they removed the backlash gears) aside.
Smooth engine which is perfect for motorway cruising, great off road, and bullet proof. Loads of cool ad ons and good value. I picked up a brand new one in 2020 for £9999 with panniers.
I tried the 900 but found the vibes really annoying at around 75-80mph, same with the new 1200.
Trouble is, if you have come from the old triple engines the t-plane just misses the spot. That's because they aren't the Triumph Triple. They're a hybrid that's not sure what it is.
The reason why I buy Triumph bikes is because of the engine, simple as that.
I've ridden and owned most of the other makes but found the triple to be just what I wanted.
Now they've decided to get ride of the reason you buy a Triumph to replace it with, er, a bit of this and a bit of that?!
I wanted to upgrade to a bigger bike as I intend to do more touring and although the 800 is great, it's a bit manic over long periods but because it's smooth, it's doable.
Now I'm getting older I want a bit more finesse.
The Gen 3 Explorer is perfect but a bit of a lump.
The new 900 and 1200 would be great with the 180 degree Triple but they don't make them.
You either stick with your 800 or change brand, none of that seems a great move by Triumph.
