Home
Search
Member Map
Photos Gallery
Login
Register
VIEW MEMBERS
ERROR LOG
MAINTAIN DATABASE
ATTACH & AVATARS
MANAGE THEMES
BLOCK LIST
Login/Register
RECENT POSTS
UNREAD TOPICS
UNREAD REPLIES
BOOK MARKS
PHOTOS GALLERY
HELP PAGES
ACCOUNT
SETTINGS
FORUM
PROFILE
MY POSTS
MESSAGES
NEW = 0
LOGOUT
Recent Posts
Please
login
or
register
LOGIN
JOIN
Triumph Tiger 800 Forum
Does anyone know what's going on??
17 May 22, 05:02 am
1
Go Down
Author
Does anyone know what's going on?? (Read 608 times)
benp1992
Tiger Member ‐
76
Topic Author
benp1992
Tiger Member
Topic Author
Bike/Model: tiger xrx
Country:
on:
May 11, 2022, 04.18 pm
Hi all,
I'm hoping one of you wonderful lot may be able to help with what's going on with my tiger.
I went for a long ride the other week 400 miles, came back washed bike, adjusted chain. Next time i went out on the bike I noticed that under quick acceleration that the bike would start to accelerate well but then at around 3-4 or 4-5k revs (gear depending) the bike would stop accelerating and judder slightly then carry on accelerating. I thought it could of been the chain so rechecked and adjusted slightly. It happened again, as the chain was near end of life anyway I chose to replace it and also the replaced the Cush drives while I was there. I went for a test ride after, started off well. I tried all types of accelerating where the problem appeared before and it wasn't there. Winner I thought......however went a little further and low and behold the fault came back again...
So I'm a bit lost now I can't work out the problem, has anyone had this issue before?
Bike Tiger 800 XRX 2015
Miles 50,000
12k service done in Nov
Fuel, Currently E10 (only 80 miles left) Could this be it??
No fault codes
Throttle bodies balanced
Only happens on quick acceleration in gear, runs fine on idle and when revved on idle
Gears select fine
Clutch replaced about 7k ago
Last Edit: May 11, 2022, 04.58 pm by benp1992
awjdthumper
Tiger Master ‐
753
awjdthumper
Tiger Master
Bike/Model: Tiger 800 XCA
Country:
Re: Does anyone know what's going on??
Reply #1 on:
May 11, 2022, 05.40 pm
Although the problem might have nothing to do with the engine, it sounds like a misfire issue which means one or more cylinders fails to produce the usual amount of power and the engine hesitates. Normally, in modern cars, they detect misfiring and even tell you which cylinder it is but, unfortunately, motorbikes don't seem to be capable of this. In general, misfiring can be difficult to diagnose and can have many causes including problems with injectors, coils or plugs.
In this case, it would be useful to know exactly when the problem happens. When you say 'quick acceleration', do you mean hard acceleration with the throttle snapped wide open and is the hesitation in every gear or just the higher gears? If you accelerate more sedately, does the problem still occur?
T800XC
Premier Member
Tiger Jedi ‐
2679
#2
T800XC
Premier Member
Tiger Jedi
Bike/Model: Tiger 1200 XRT
Country:
Reply #2 on:
May 11, 2022, 05.58 pm
Originally Posted by
awjdthumper
Although the problem might have nothing to do with the engine, it sounds like a misfire issue which means one or more cylinders fails to produce the usual amount of power and the engine hesitates....
Could be caused by a leaky throttle body? I'm sure something similar has been mentioned on here before.
benp1992
Tiger Member ‐
76
Topic Author
#3
benp1992
Tiger Member
Topic Author
Country:
Reply #3 on:
May 11, 2022, 07.17 pm
Thanks for the replies both. I was just thinking about potential coil issues and maybe a missfire but thought they may occur when I try and replicate at idle?
If I ride very sedately it doesn't do the problem, only when asking for a bit more go.
Tripple3
Tiger Member ‐
41
#4
Tripple3
Tiger Member
Reply #4 on:
May 11, 2022, 07.29 pm
Did you run bike after washing it? Maybe some water has got somewhere after washing it.
awjdthumper
Tiger Master ‐
753
#5
awjdthumper
Tiger Master
Country:
Reply #5 on:
May 11, 2022, 07.35 pm
By their very nature, a mis-fire problem will be worse the more you put the engine under load - that is, when you are accelerating.
chuckxc
Tiger Jedi ‐
1150
#6
chuckxc
Tiger Jedi
Bike/Model: 12XC, 18XCX
Country:
Reply #6 on:
May 11, 2022, 10.13 pm
As Tripple3 mentioned, check for good spark. Note...your problem started after you washed it, ie coils, plugs, water ingress, etc.
benp1992
Tiger Member ‐
76
Topic Author
#7
benp1992
Tiger Member
Topic Author
Country:
Reply #7 on:
May 11, 2022, 11.36 pm
Thanks all, tank off tomorrow it is then
Georgeinabz
Tiger Pro ‐
108
#8
Georgeinabz
Tiger Pro
Bike/Model: 800xr
Country:
Reply #8 on:
May 12, 2022, 07.16 am
T800XC
Triumph recommend fuel hoses are changed after 4 years , not sure why but they could be collapsing restricting fuel supply
benp1992
Tiger Member ‐
76
Topic Author
#9
benp1992
Tiger Member
Topic Author
Country:
Reply #9 on:
May 14, 2022, 09.49 pm
Hey all
Thanks for the replies. Problems seems to of gone now. I changed all 3 plugs and changed the coils. (Triumph wanted £100 each!!) So I bought some from a bike breaker and all seems to be well. Hopefully it stays that way
1
Go Up
Where did my fuel go?
Misc Technical Help Required
healdem
Today
at 04:04 am
First Crash
K1W1
Yesterday
at 10:19 pm
Lowered centre stand
For Sale
Phil_from_Derry
Yesterday
at 09:58 pm
To buy or not to buy?
peterjfox69
Yesterday
at 09:30 pm
How to install a Beak (high level front mudguard)
"How To" Technical Articles
Free-Spirit
Yesterday
at 07:22 pm
Loving my Tiger
New Members
Tigerfirst
Yesterday
at 05:52 pm
Insurance renewal
PapaTom
Yesterday
at 05:35 pm
Tiger 800xc preload tension adjuster wrecked?
rrrideadvgal
Yesterday
at 04:28 pm
Hey Tiger brothers!!
New Members
PapaTom
Yesterday
at 04:24 pm
2011 Tiger 800 XC
For Sale
jakeyt
Yesterday
at 03:48 pm
