How about we approach the mapping question from another direction.
I have a Commander V system which measures the actual AF Ratio. (on the bike when I bought it s/h) It adjusts the AF by adjusting the injector volumes as per whatever AF values have been loaded into the Tables.
So I also have the Auto Tune module which allows me to set a preferred AF and the Commander will map that and the Auto Tune Module (eg currently on 13.2 ) will dynamically adjust the AF by applying plus or minus adjustments to the injectors after the black box program..
The AF range available is approx plus or minus 20%n the black box. So when I read those suggested change tables it shows HUGE injector variances to maintain the set AF. (you can accept those tables and CV will start at those values and ATune will then apply subtle changes.)
The reason I am putting this out there is that now that I have played with various maps - the change in performance is dramatic.
Read that to be DRAMATIC
Its probably not about more raw HP but the acceleration and torque is on another level.
Whilst I haven't been back to have it dyno'ed, I see no point as he told me to go out and play with the Auto Tune and maps. Tick.
The Tuner created and loaded the first simulated Map, disabled the pair system so that we are now getting a true exhaust meter reading and by activating the Auto Tune in the s/ware it has transformed the Bike.
My first Map smashed the rideability set up on the Dyno map. First surprise.
Read on because this is where it gets interesting.I fitted some new decat headers last year and set Auto Tune to 13.5 AF which changed rideability enormously in every aspect ... from throttle roll on at any speed and any gear. Totally blown away by that change. Different bike altogether. Gotta watch the speedo more!
Then got some advice from a master tuner (MAX Suzuki Forum in the US) and currently running a 13.2 'performance' Map and it pulls like a TRAIN. MPG is still consistently 20klm per Ltr over a full tank ... whatever the riding, and I also went up 1 tooth on the c/shaft and it feels easy, in fact it feels like what the ratios should be without having to change so many gears.
I am now first across the intersection because it pulls off throttle so easily. (PITA off road but, first is even higher)
Therefore my advice to those loading 'Maps' is, every time you change something like pipe = Akrapovic for me, air filter = K&N with pre filter and headers (Delkevic) you have just thrown your Map out the window !!!
even if it was ever a proven to be a good map.
How do you even know what the Map is doing ....
I recently bought another CV module which actually shows me real time AF on the display ... boy does that thing work hard and you need to be on open road to try and monitor what is happening. You cant video it but there is a way to save those files apparently.
So in my testing, I can see what the ATune is doing and prove live that I am circa 13.2 + or - one or two points before it adjusts back to 13.2 AF.
Bottom line is if you haven't dyno'd how do you know???
Your eyes would roll back in your head if you saw one of your "maps'' in real time, and in particular on the seat / out on the road - not on the dyno. (there are very different dynamics comparing the two)
I would guarantee you that map / fueling is going to be all over the ship! Seriously. Particularly given my first and original dyno map was very very average compared to my first real 'ride' map on ATune.
Compare that to the original performance of the bike when bought, running no Maps (he hadn't turned on the ATune haha) so with stock fueling, lots of noise with a Scorpion pipe it was horrid to ride and I wondered if I had made a mistake.
Now its hit the button and its giving me 100% proven AF performance all day everyday.
