Author [NL] [FR] [ES] [DE] [SE] [IT] 2018 xrt - rox risers and wiring  (Read 725 times)
  • Online Jemil   england
    • Tiger Member  ‐    14
    Online Jemil
    • Bike/Model: 800XRT
    • Country: england
    on: May 31, 2022, 05.31 pm
    Hi all
    I had my roadie booked in to fit rox risers as I need the bars to come back a bit, but Triumph just called and said the loom and other cables are too short and so can't fit them. I had read elsewhere on here this was always a possibility - just wondered if anyone had any suggestions as to what else I might try? short of asking Triumph to extend the cables (which I imagine isn't cheap)
    Cheers!
  • Online Stevie.P   gb
    • Tiger Jedi  ‐    4827
    • Bike/Model: 2015 Tiger XRt
    Re: 2018 xrt - rox risers and wiring
    Reply #1 on: May 31, 2022, 07.12 pm
    I don't think there is a major handlebar difference between 'Gen 2' and 'Gen 3' bikes other than TFT screen. I suspect the dealer simply isn't prepared to do cable/wiring alterations from standard routing, when in reality little is needed. I have both XC risers and Rox risers fitted with no cable/wiring extensions needed just the wiring ties relocated.
    Reply #2 describes what was needed and the link in the reply shows pictures.
    https://www.tiger800.co.uk/index.php/topic,30123.msg321759.html#msg321759
    • Tiger Member  ‐    14
    • #2
    Online Jemil
    • Country: england
    Reply #2 on: May 31, 2022, 08.30 pm
    Thanks StevieP, you're likely right - its probably a liability thing.
    I've got a few days off, if its dry I'll have a look myself which I was hoping to avoid, as a noob  :008:
  • Offline GeoffS   wales
    • Tiger Master  ‐    724
      #3
    Offline GeoffS
    • Everyone with telekinetic powers, raise my hand.
    • Bike/Model: XC - Green/Black
    • Country: wales
    Reply #3 on: May 31, 2022, 08.37 pm
    Hi Jemil
    Fitting Rox risers is pretty straightforward, and shouldn’t (hopefully) require any adjustment to cables. Check out MuddySumps videos; he’s done one specifically on fitting these risers.
    Geoff
    Roses are red,
    Violets are blue,
    Some poems rhyme,
    But this one doesn’t.
  • Offline K1W1   au
    • Tiger Jedi  ‐    5261
      #4
    • Up in the hills
    • Bike/Model: XRX
    • Country: au
    Reply #4 on: Jun 01, 2022, 12.15 am
    *Originally Posted by Jemil [+]
    Hi all
    Cheers!
    AFAIK the Roadie (XR) versions and the Off Road (XC) versions use the same wiring loom and the XC bikes come standard with a riser fitted so what the dealer is saying simply does not make sense. Couple that with the fact that for the last 12 years people have been adding Rox or other risers to Tigers generally without any issue and it makes the dealer looks even more silly.
  • Offline chico   us
    • Tiger Jedi  ‐    1462
      #5
    • Bike/Model: 2017 XRX
    • Country: us
    Reply #5 on: Jun 01, 2022, 05.36 am
    As Stevie, Geoff and K1W1 stated, Adding Rox risers is one of the easier mods you can do to your bike, as many have done it. Either the dealer's mechanic is incompetent or the dealership wants to make extra income. Those two conditions are the reasons why after I pick up my new bike the dealer doesn't get to see or touch the bike, unless there is a warranty or recall issue.
    You can do this yourself. You'll need a ratchet and a set of hex bits.
  • Online markymark11   gb
    • Tiger Pro  ‐    207
      #6
    Online markymark11
    • Bike/Model: 2015 - 800 XRX
    Reply #6 on: Jun 01, 2022, 07.40 am
    Just a thought - do you know which size Rox Risers you have - they do about 5 different variations in size.
    If you get stuck or nervous, depending where in Surrey you are, if you fancy a ride out to Basingstoke then PM me and I will gladly help you fit them over a cuppa. I have all the tools necessary and already have risers on my XRX  :001:
    Last Edit: Jun 01, 2022, 07.49 am by markymark11
    • Tiger Member  ‐    14
    • #7
    Online Jemil
    • Country: england
    Reply #7 on: Jun 01, 2022, 08.08 am
    *Originally Posted by markymark11 [+]
    Thankyou for your very kind offer! I'm not so far from you (New Haw) - I will watch the vids and give it a go. They're the 2" pivot risers - I looked around for others that were shorter (I really only need them to come back toward me about an inch), but went with these as they seem popular amongst the community.
    Will report back!
  • Offline Paulhere   gb
    • Tiger Jedi  ‐    2289
      #8
    • Bike/Model: Tiger 800 XRx
    Reply #8 on: Jun 01, 2022, 09.31 am
    I recently fitted 2" Rox risers to my '16 xrx. On full left lock/locked position, the harness from right bar end is a tad tight, made worse by clutch cable pulling on it. I re-routed the clutch cable from in front to behind the harness, which eased it, the harness is routed between the two tubes that hold the panel/lights, it pulls against the top tube, not too tight now.
  • Offline blunderbust   gb
    • Tiger Member  ‐    24
      #9
    Offline blunderbust
    Reply #9 on: Jun 28, 2022, 10.57 pm
    Did my 2019XRx with 2" rox risers and found that removing the routing bracket and banding the control cables together gave me full movement with no problems.
    Ride Safe.
