Author [NL] [FR] [ES] [DE] [SE] [IT] HELP - Bike will not run !!!  (Read 785 times)
  • Offline sezian   gb
    • Tiger Master  ‐    607
    Offline sezian
    • North Kent Coast
    • Bike/Model: Tiger 800 Roadie
    • Country: gb
    on: Jun 01, 2022, 11.43 am
    Bike has been running fine, filled up with petrol after a 30 mile ride, bike started and cut out, would not tick over - Now before you say stepper motor I've always kept this clean and never had a problem. And no I don't suspect the fuel to be a problem.
    I was able to ride the bike a further 60 odd miles and it would tick over most of the time, stalled a couple of times, also when throttle was shut off in say second gear the bike seemed to be idling to high as it would drive itself. Obviously something wrong here.
    I've stripped the bike down, again cleaned the stepper motor and lubricated with GT85 PTFE, put back together starts but will not tick over. I've just ordered a new set of plugs, although I'm dubious that this is the problem as I only serviced it about 500 miles ago (36,000 miles - New plugs, air filter, etc, Valves checked by David).
    Checked on DealerTool and no fault codes showing  :187: :187: :187:
    Anyone got any ideas what this might be ???
  • Online T800XC   ua
    • Tiger Jedi  ‐    2726
      #1
    Online T800XC
    • Bike/Model: Tiger 1200 XRT
    • Country: ua
    Re: HELP - Bike will not run !!!
    Reply #1 on: Jun 01, 2022, 12.07 pm
    Sounds like it could be a faulty throttle position sensor. Use Dealertool to check that the TPS voltages are within spec.
  • Offline sezian   gb
    • #2
    Offline sezian
    • North Kent Coast
    • Country: gb
    Reply #2 on: Jun 01, 2022, 12.22 pm
    Okay thanks, not sure where to find this on DealerTool can you point me in the right direction ?
  • Online T800XC   ua
    • Tiger Jedi  ‐    2726
      #3
    Online T800XC
    • Country: ua
    Reply #3 on: Jun 01, 2022, 12.32 pm
    Select 'Sensor Values' from the top of the interface then look in the tab labelled 'Page 4' in the pop-up window.
    Also worth a look on Page 0 at 'Throttle %', 'Idle Steps' and 'Target Idle Speed'.
  • Offline sezian   gb
    • #4
    Offline sezian
    • North Kent Coast
    • Country: gb
    Reply #4 on: Jun 01, 2022, 04.31 pm
    Thanks Richard, can you tell me what values I'm looking for?
    Just selected this and I can see engine not running it was 7. something volts and when the bike started up it was running at 6 something. I can check exact values if that helps?
    Also if I replace the TPS with new (about 100  :005:) is this just a plug and play or is there some setting up procedure?
    All info much appreciated  :028:
  • Offline sezian   gb
    • #5
    Offline sezian
    • North Kent Coast
    • Country: gb
    Reply #5 on: Jun 01, 2022, 04.49 pm
    Just noted exact TPS voltage readings:
    Bike not running - 0.718 volts
    Bike running - 0.698 volts
    Is this where it should be  :187:
  • Offline Georgeinabz   scotland
    • Tiger Pro  ‐    114
      #6
    Offline Georgeinabz
    • Bike/Model: 800xr
    • Country: scotland
    Reply #6 on: Jun 01, 2022, 06.56 pm
    Target Voltage Range on fully closed , which you need to command by dealer tool ,is 0.58- 0.62v
  • Offline sezian   gb
    • #7
    Offline sezian
    • North Kent Coast
    • Country: gb
    Reply #7 on: Jun 01, 2022, 08.43 pm
    How is this achieved?
    Is there someway to adjust using DealerTool ?
    • Tiger Pro  ‐    114
      #8
    Offline Georgeinabz
    • Bike/Model: 800xr
    • Country: scotland
    Reply #8 on: Jun 02, 2022, 09.06 am
    PM sent
