Author [NL] [FR] [ES] [DE] [SE] [IT] Cruise Control  (Read 328 times)
  • Offline LegionRider   gb
    • Tiger Cub  ‐    4
    Offline LegionRider
    • Bike/Model: Tiger 800 XRX
    Cruise Control
    on: Jun 07, 2022, 06.01 pm
    Hi, 2019 800 XRX.. no CC. Tried the sequence on the 1200 page.. still no CC.. only 1404 miles from new
    Any suggestions?
    TIA
  • Online Thripster   gb
    • Tiger Pro  ‐    142
      #1
    Online Thripster
    Re: Cruise Control
    Reply #1 on: Jun 07, 2022, 07.54 pm
    Try travelling at 30mph or above in 3rd gear in or higher. Press set twice......should be fine. The manual indicates how to engage. Alternatively, have you modified the clutch lever?
    • Tiger Cub  ‐    4
    • #2
    Offline LegionRider
    Re: Cruise Control
    Reply #2 on: Jun 07, 2022, 08.05 pm
    No mods done to bike..
    4th gear and 35 mph .. still no joy
  • Offline pahiker
    • Tiger Member  ‐    54
      #3
    Offline pahiker
    • Bike/Model: `21 Tiger 900GT
    Re: Cruise Control
    Reply #3 on: Jun 07, 2022, 08.32 pm
    Is this the sequence you tried? This is from our forum and worked for me.
    Key in off position
    Kill switch in [X] (off) posiition
    Put bike in Neutral
    Sit on bike, kickstand up.
    Make sure the CC is off (pre 2017)
    Turn on Key
    Turn on Ignition (Red lever kill switch on / down)
    Green light for CC should be blinking
    Start the reset sequence:
    Activate the Front Brake Switch by pulling and releasing the front brake
    Activate the Rear Brake Switch by pressing and releasing the rear brake pedal
    Activate the Clutch Switch by pulling and releasing the Clutch
    Activate the Twist Grip Cruise Control cancel switch by operating and holding the throttle grip in the fully closed position
    Press the Cruise Control On/Off switch to ON (on the ’15, +/Accel switch on '17)
    • Tiger Cub  ‐    4
    • #4
    Offline LegionRider
    Re: Cruise Control
    Reply #4 on: Jun 07, 2022, 09.34 pm
    Yes.. tried to 4 times.. but to no avail..
  • Offline chuckxc   au
    • Tiger Jedi  ‐    1183
      #5
    • Bike/Model: 12XC, 18XCX
    • Country: au
    Re: Cruise Control
    Reply #5 on: Jun 07, 2022, 10.45 pm
    I'm sure you know to push the switch twice to first engage but mention it anyway.
    It is important that both front and rear wheel speed sensors are clean and aligned. Check that on the wheel rotor slotted discs. You will know because the ABS warning light will not go out once you start riding.
